I recently bought a VWR Polysciences 1162 refrigerated circulating water bath for $600 (instead of $1000s) (see attached).
I've noticed that when I am trying to maintain a temperature of 18degC (about 7degC below ambient) the compressor turns off every 10-20 minutes for about 5 minutes. This doesn't seem right. I don't know if there's a controller fault, low refrigerant or overheating. I have attached a temperature vs. time of day graph. The start of each blip is when the compressor switches off. There's a small initial rise because the heating continues. Eventually the compressor kicks back in.
My main concern is if this is okay behavior (I can live with temp control within 1degC but would prefer better) or if it is something that will damage the unit.
Any pointers to service manuals (generic or otherwise), advice etc will be most gratefully received
(web searches haven't been much use).
Thanks,
John.
