Author Topic: Trotec IC060 thermal cam repair  (Read 2349 times)
Offline BFXTopic starter
  • Country: sk
« on: March 30, 2016, 11:17:12 pm »
Welcome in the hell  8)
I bought this camera on ebay because of symptoms (is possible to turn on after enough tries)
It's look like power source problem (obviously capacitor).
But :D
It's no so easy as seems to be :)
There is no service manual, nothing.
I started from beginning .. power supply
Everything is rear-lacquered:( When I can measure something I need to scrape the contacts :phew:
Next straight forward step check all capacitors ... hmm tantal :)
All seems to be OK and next step was connect additional boards to check if power consumption will increase.
But nothing.
When I put together all boards camera looks good started but on display si only one vertical line and after that nothing.
Some photos:
There is lot of potential problems like RAM, CF card, display, CPU or FPGA.
Suggestion's are welcome.
To be continue ...  8)
« Last Edit: September 26, 2016, 11:48:39 am by BFX »
  • Country: sk
Re: Trotec IC060 thermal cam
« Reply #1 on: September 25, 2016, 08:05:02 pm »
Back to repair and little late update. 8)
I did some measurements and testing and finally CF card is broken.
I think CF card contains standard FAT partition for pictures, but also some non-standard segment which contain firmware.
Question:
Know somebody about any tool to repair complete data from CF card? Something like ghost for standard HDD?
  • Country: sk
Re: Trotec IC060 thermal cam repair
« Reply #2 on: October 02, 2016, 09:56:11 pm »
Good news 8)
CF card is still bad, but after format on PC camera working fine.
Sometimes is problem to bootup sometimes save of image failed but working.
Definitely I should buy new CF card.
