Author Topic: portable oven earth leakage trip  (Read 1715 times)
Offline phaseformTopic starter
« on: April 10, 2016, 08:32:59 am »
I've gotten a hold of a plug in oven which after working fine for a few days has tripped the RCD device. Now the RCD won't even switch back on. I'm not exactly sure about earth leakage principals, the device is showing a measurable resistance between one of the mains pins and the ground. I have disassembled the device and it seems both the top and bottom heating elements each show a measurable resistance to the earth pin. I'm assuming the oven is junk now?
Offline Totalsolutions
Re: portable oven earth leakage trip
« Reply #1 on: April 10, 2016, 09:22:52 am »
I would say so. Howabout replacing the heating elements ?
Sent from my GT-N7100 using Tapatalk
Paul
« Reply #2 on: April 10, 2016, 09:24:33 am »
Ehh I can probably buy one off Gumtree for $30 or find a better solution.
On another note I've evidently been in this waiting room over an hour
« Reply #3 on: April 10, 2016, 09:43:32 am »
You can disconnect both ends of the elements, which will then tell you which one has the leakage. You can buy a replacement element if the oven is expensive, but for a cheap one ( cheapest I have seen retail is $15 this week, though it is barely big enough to get a dinner plate inside it) just scrap it.
If you find the faulty element you can get the moisture out of it by heating up with a small gas torch for a few minutes, getting it to over 200C for a few minutes will drive the adsorbed moisture out.
