Hi I've recently acquired a 'Marley Get-togther', a fairly expensive and good-sounding speaker that has Bluetooth as well as analog inputs.
The mute-circuitry is way too aggressive though - you can't use it to watch a movie at all, or listen to any music with quiet or silent sections. And it has a lag as it comes out of mute.
I took a look inside and found an STA559BW '2.1 channel high-efficiency digital audio system Sound Terminal' (
https://www.st.com/resource/en/datasheet/sta559bw.pdf). I believe its doing the muting internally, and this is configurable in a register. I traced back the I2C lines and they go to something that I am assuming is some kind of PIC with built-in flash. Part number SS(i?)95f116.
I checked the power supply, power-off and reset lines of the STA559BW and none of them are changing as this thing goes in and out of mute.
I think the proper way to disable the mute would be to download the firmware of the PIC (if possible?) reverse-engineer it, but I'm not set up for that and that seems fairly involved. What other options do I have? Would there any easy way to spoof an input signal, without causing audible noise or affecting sound quality?
Thanks y'all
