Author Topic: Possibility of repair for Sony KV-21X5U CRT TV  (Read 5362 times)
Online HwAoRrDkTopic starter
« on: August 09, 2022, 04:43:42 pm »
I have an old Sony 21" CRT TV, model KV-21X5U, that I recently got out of storage because I want to use it with something that would benefit from being viewed on a CRT.
However, it worked apparently fine for about 30 minutes, then all of a sudden the picture cut out, and now it doesn't want to play ball any more. There was also a slight smell emanating, of the usual 'too-hot electronics' or 'capacitor spilled its guts' odour. :( Its behaviour now is as follows: when power is applied, there's the usual 'fizz' from the CRT, then about 4-5 'clicks', then it will start flashing the power LED in a regular pattern - 2 flashes, pause, repeat, and so forth - and do nothing else.
I found the service manual online, which has full schematics, etc. It also has a table of diagnostic error codes which correspond to the LED flashing. It says that two flashes mean "protection circuit trip".
Am I right in thinking that the 'protection circuit' is a feature found in CRT displays that has something to do with detecting when the high-voltage to the tube is excessively high, so that it does not start emitting x-rays? That is my dim recollection anyway; I don't know much about CRTs and their circuitry.
I'm wondering whether this is something worth pursuing for a repair, if the problem is something related to the HV parts of the TV. I'm not keen on dealing with any of that, given my lack of experience in such matters.
I opened the TV up anyway, just to get a look an see if there's anything immediately noticeable wrong, but I couldn't find anything. No bulging or leaking caps, no blown, charred or otherwise noticeably overheated components. Apart from everything being filthy dusty, everything looked perfect. I did notice there's a large relay on the board (which according to the schematic is used to switch mains power in when it comes out of standby), but I'm not sure if that was what was doing the clicking/ticking noise.
Any suggestions for narrowing down the cause of the problem? Schematic-only version of the service manual attached below if it helps.
Online inse
Re: Possibility of repair for Sony KV-21X5U CRT TV
« Reply #1 on: August 09, 2022, 05:56:57 pm »
Just a blind guess: there is always the chance that the flyback HV transformer is defective and leaks to the outside or arcs internally, try to localize the sourc of the 'clicks' or watch for discharges in darkened environment.
Also check the HV capacitors C542/3/8 C553/5 for cracks.
Protection circuit can mean overcurrent protection in the power supply or X-ray protection from excessive HV.
« Last Edit: August 09, 2022, 05:59:35 pm by inse »
Offline SoundTech-LG
« Reply #2 on: August 09, 2022, 07:10:23 pm »
HVT +1   unobtainium???
« Reply #3 on: August 09, 2022, 07:49:22 pm »
I tried powering-on a few times again, and the rapid clicks are not coming from the relay (although that does clunk on, then off right as the clicks stop). I couldn't narrow it down too much - don't feel like putting my head right in close to the HV stuff! :scared: - but it seems like the clicks are coming from around the large transformer T603.
I checked them, they all look fine. They're nearly all through-hole dipped epoxy-package parts, and I couldn't see any cracks in the shell. C553 doesn't look like any capacitor I've ever seen, though. It's a tall, thin glass-like looking package, and it's right up against the heatsink for Q533, touching, as if it were some kind of temp sensor. Whatever kind of cap it is, it looks fine too. Edit: on the schematic, it's labelled as 'PT', and there's a legend on another page which says that means a mylar cap.
I think tomorrow I might check the voltage on the +9V and +5V rails from IC604 & 605. I would assume if there's some kind of problem with T603 shorting, its output would be compromised? I already checked the 5V standby output (at IC608), and that's fine.
« Last Edit: August 09, 2022, 07:59:18 pm by HwAoRrDk »
Online inse
« Reply #4 on: August 09, 2022, 08:19:33 pm »
You can also do the good old bulb test: disconnect the FBT from the B+ voltage and load the B+ rail with a 40W bulb.
If it glows, the power supply is delivering and the failure must be in the FBT/control or deflection.
With too much uC intelligence, such modifications also might result in a dagnosis failure and shutdown.
A good idea is to watch the power consumption of the set for irregularities/overload.
« Last Edit: August 09, 2022, 08:22:28 pm by inse »
« Reply #5 on: August 10, 2022, 12:09:51 pm »
I measured some more voltages today. The main +5V (at IC604), +9V (at IC605) and +B (at R571). They don't look at all good: +5 = 0.2V, +9 = 0.7V, and +B fluctuating around 6-7V. The input to the 9V regulator was also only 1.7V. All the voltage rails were slow to rise; these figures are the maximum I saw before the main relay clicked off (and the error code starts flashing).
If the problem is a shorting transformer, then I don't fully understand how the main microcontroller is detecting that something is wrong. Although, from looking at the schematic, it seems perhaps it can possibly determine the status of +B through Q571/Q574/Q011 which lead to the micro pin labelled "XRAY PROT", which I guess by the name does tie in with a protection circuit fault.
I don't actually have any incandescent bulbs in the house! ;D
Online inse
« Reply #6 on: August 10, 2022, 04:44:23 pm »
Did you measure the voltages when the set tries to power up or after it has shut down?
Do you have a powermeter to check the power consumption?
Unplug the degauss coil to see whether the set draws excessive current at startup.
Disconnect the supply rails one by one to find out if one of them is overloading the power supply.
Online inse
« Reply #7 on: August 12, 2022, 05:17:51 pm »
No further efforts to repair the set?
« Reply #8 on: August 12, 2022, 07:21:22 pm »
Sorry, I haven't had the time to look at it recently. I plan to tackle it again over the weekend.
By the way, those voltage I previously measured were when it tries to power up, before it shuts down (or, rather goes into standby error state).
By power meter, do you mean mains power? I have a Kill-A-Watt-style mains power meter, but I doubt it'd be too useful. The display on that only updates once per second, and the whole power-on-to-error-shutdown period only takes about 3 seconds, so it'll be "blink and miss it".
I don't know whether I can disconnect any of the supply rails - that'd mean starting de-soldering stuff off the board.
Online inse
« Reply #9 on: August 12, 2022, 08:31:41 pm »
I am confused, first I thought the 'fizz from the CRT' was the HV building up, but that's not possible with a B+ voltage of only 6…7V.
Is the fizz the degauss coil? Please disconnect it as already suggested.
Yes, you will have to engage the soldering iron to isolate the assumed overloaded rail.
« Reply #10 on: August 12, 2022, 09:07:10 pm »
I assume the degaussing coil is connected to the connector marked "DGC" (CN602) on the schematic? I just looked, and that connector does indeed go to a couple of loops of cable around the tube. I will try with and without that and try to measure the current draw.
Although... looking at the schematic, the degaussing coil seems to be directly across the AC mains input (with current limited by a PTC thermistor), before main transformer and even bridge rectifier. So, if that was drawing too much current for some reason, wouldn't it blow the main fuse?
Online inse
« Reply #11 on: August 12, 2022, 09:12:51 pm »
The idea is to eliminate any additional current paths and noise sources to only concentrate on the electroncs.
« Last Edit: August 12, 2022, 09:14:47 pm by inse »
« Reply #12 on: August 13, 2022, 05:00:57 pm »
I tried measuring the mains current draw using my plug-in watt-meter. With the degaussing coil still connected, it drew about 0.6-0.7A (@ 240V) peak during the repeated 'clicking' noises. Then I unplugged the DGC from the board and repeated. The current draw was essentially the same - around 0.6A.
After repeating this a few times to verify and getting the same results, I had a quick look across the board to see where the PTC thermistor (THP601) that is part of the DGC circuit is. I found it, and discovered that it was very hot. Almost too hot to touch! Is it supposed be doing that? I also really can't comprehend why it is a 3-pin device if it's for some kind of current-limiting.
Online inse
« Reply #13 on: August 13, 2022, 08:21:28 pm »
Yes, thats the normal behaviour, the degaussing will only occur during the heating phase.
The PTC needs to cool down for several minutes to re-start the degaussing.
What influence to the fizz did you observe?
« Reply #14 on: August 13, 2022, 09:20:52 pm »
Oh, I see. I guess the repeated on-off in a short period made it much hotter than normal. :-[
The 'fizz' didn't occur with the degaussing coil unplugged.
Offline wasedadoc
« Reply #15 on: August 14, 2022, 05:10:03 am »
No, the PTC was not hotter than normal. It needs to be hot to have high enough resistance to reduce the current through the degauss coil.
3 leads because sometimes the component is a combination of a PTC and NTC in series. The coil is in parallel with the NTC.
« Last Edit: August 14, 2022, 05:15:01 am by wasedadoc »
Offline andy2000
« Reply #16 on: August 14, 2022, 03:23:16 pm »
It looks like x-ray protection in this set is triggered by excessive B+, rather than excessive HV, so a power supply regulation problem would be my first suspect.  Unless you're using an oscilloscope to check the voltages, I doubt you can get an accurate reading before it shuts down since it shuts down the instant it detects excessive voltage.  IC603 could be bad.
You could remove the horizontal output transistor to test it, and also to reduce the risk of damage while you're working on it.  If it's not a false protection trigger, then every time you turn it on with excessive HV, you risk causing serious damage.
With the HV disabled (by removing the HOT), you could try disabling the protection circuit to give you a chance to check the power supply voltages.  Pull the plug quickly if it goes much over 135v.  You may need a dummy load on the B+ to get accurate readings, but not usually.
Some sets will also shut down for other reasons such as loss of deflection, or excessive beam current, but not often on a small direct view set like this.
Online inse
« Reply #17 on: August 14, 2022, 03:45:42 pm »
We do not have an indication that B+ is present anyway, I still suspect that the power supply is shutting down due to overload.
Please test whether the HOT Q533 is still OK by measuring B-C and B-E with R549 disconnected.
If the HOT has failed there is a good chance that this is a secondary effect, either due to poor control signal or failure of the FBT or damping circuit.
« Last Edit: August 14, 2022, 04:58:26 pm by inse »
« Reply #18 on: August 16, 2022, 03:56:36 pm »
I de-soldered one leg of R549 and measured Q533:
B-C: 0.32V
B-E: <0.01V
E-B: <0.01V
C-B: 0.39V
C-E: 0.38V
Q533 is either a 2SD2539 (according to schematic) or 2055N (according to parts list), and from datasheets I was able to find of either, it has built-in B-E pull-down resistor, as well as a C-E "damper" (snubber?) diode. I'm guessing this will complicate measurements. However, despite the B-E resistor, I don't think it should measure effectively short-circuit B-E/E-B on diode-check, nor 9 ohms on resistance. According to one datasheet, B-E resistor should be approx. 50 ohms.
So, I'm guessing this transistor has failed?
IC603 could be bad.
Is there any way of testing this IC?
Datasheet describes it as a 135V "error amplifier". I assume its job is to drive the optocoupler to give feedback to the switch-mode controller IC606, so that 135V is maintained on +B.
Online inse
« Reply #19 on: August 16, 2022, 07:38:30 pm »
C-E anything below infinity is generally bad if it is the transistor alone.
Desolder the transistor at the emitter and see whether B+ comes up.
« Last Edit: August 16, 2022, 07:40:19 pm by inse »
« Reply #20 on: August 16, 2022, 09:04:34 pm »
Okay, good, that's what I thought - that C-B and C-E should read 'OL' on the meter.
I'll give that a go. Going to be tricky - will probably have to de-solder the whole part, remove it, bend the emitter lead, then re-solder.
So, one thing I'm confused about: should B+ be 135V, or 200V? I'm sure I saw a label against it on the schematic that said "200V", but I may be mistaken.
Online inse
« Reply #21 on: August 16, 2022, 10:06:54 pm »
You're joking
Either the hole is big enough so that the pin can be isolated by sucking off the solder or you remove the entire part.
I'd expect 135V for the B+, any hints on that in the manual?
Offline FIXITNOW2003
« Reply #22 on: August 17, 2022, 06:47:26 am »
FE1 Chassis fault list if it helps
FE KV25X5U   Int no pic with LED flashing 4 times   O/C print from pin 14 of IC301 to first link wire.
FE1   Buzzing only on sound from tuner - ok on AV   Incorrect sound system selected, the cause being memory corruption. To correct the problem, enter test mode to obtain "TT - -" on screen, & type in "24". This will reset sound system back to PAL I. Turn  set off & re-tune, & sound should then return to normal.
FE1   Dark pic   The ABL circuit is operating incorrectly. Replace R516 (56K) & R517 (10K or 27K depending on CRT)
FE1   Dead except for st/by LED flashing twice   oscillator STR & phototransistor 123 & FOP chip STV
FE1   Int blows LOPTr   check line dr tx but was dry joints jungle i/c pins  IC301this time
FE1   No power (no standby power supply o/p)   Replace IC609 (TOP209) also check C640 (47µF, 25v), D631 (MTZJ-12B), D628 (P6KE200), D629 (µF4005PKG23) and R627 (4.7?,)
FE1   Reverts to st/by at sw on with 2 or 4 flashes from LED   2 flashes indicates an over-current error in line stage, & 4 indicates a frame fault. However, quite often, when 4 flashes occur it can still in fact be an over-current error as well as a frame fault. To prove which is the correct fault, measure pin 52 of the micro (IC001) at switch-on, and if this voltage goes high (anything above 0.6v) then it is in fact over-current. If it stays at 0v then the fault is more than likely within frame stage.
FE1   Set shuts down shortly after start up with standby led flashing 2, 4 or 5 times   Check SMD resistors R543 (47K) and R541, R573 and R575 (all 100k)
FE1   Snowy pic & tone on sound   IC001 micro faulty
FE1    After about 30 minutes the set goes to standby, the LED flashes and TV starts again. After 1 Minute the TV Displays : Antenna connection failed!   Change IC101 of IF on A-Board. Order Nr. 875946647
FE1    Band of interference down left of screen on dark scenes   This was cured by adding a 1000pF, 2kV capacitor (part no. 1-161-731-81) in parallel with D539 in the EW diode modulator circuit
FE1    Excessive width   Q532 (2SK2251-01) s/c, it is advisable to also check other EW circuit components as a precaution
FE1    Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times   This was due to the CRT being faulty
FE1    Loss of one colour with teletext and on-screen displays   Check the appropriate 2SC2412K transistor Q007 (green), Q008 (blue) or Q009 (red)
FE1    Main psu starts up then almost immediately shuts down   This was due to IC603 (SE135N) being faulty
FE1    No picture or dark picture   Check R516 (56K, 0.5w) or R517 (27, 0.25w) for high resistance or o/c
FE1    No power although relay operates (main psu inoperative)   Check IC606 (STRF6654) for failure, also check resistors R659 (0.33?,3w), R660 (0.39?,3w), fusible resistor R603 (0.1?,0.5w) and capacitor C625 (100µF,25v)
FE1    No remote control operation   Check as necessary D203 (MTZJ-5.6B) on main pcb, D907 (MTZJ-9.1A) on pcb H1 or the remote control sensor IC900 (SBX1981-51), part no. 8-742-014-11
FE1    No sound   This may be remedied by entering TT24 in the service mode, if fault persists Q202 (2SC2412K) could be leaky
FE1    No teletext just P100   This problem was caused by Q405 (2SC2412K) being s/c
FE1    Pressing the screen format button displays wide, smart, zoom and 4:3 modes but settings have no effect on picture   Enter TT35 in the service mode to select a 4:3 CRT
FE1    Purple line down picture   Replace IC301 (CXA2060AS), part no. 8-752-082-35
FE1 KV21X5U   burst of EHT then shuts down with LED flashing error 2   regulator IC603 SE135N (874992061)
FE1 KV21X5U   pic closing in from sides and going off (poor HT regulation)   error amp IC603 SE135N (874992061)
FE1 KV25K5U   Dead with LED blinks 4x - excess current prot mode   LOPTx T511 1145326411 shorted turns
FE1 KV25K5U   Dead with LED flashing 4 times   Check for 9v at pins 33 & 34 IC301. If present, check R546 47R 1/2w for o/c (135v Line dr supply)
FE1 KV25K5U   Error code - 2 flashes   2SD2539 LOPTr leaky & dry joint on line drive transformer. Orig Tr = 10UKP - used BU2520DF in lieu
FE1 KV25K5U   lines across screen, frame IC running hot   C506 0.01 uF
FE1 KV25K5U   No sound or vision, front led flashing   Replaced line output transistor, resoldered dry joints on driver transformer. Also check for any other poor joints in this section. Have used a 2SD1878 as replacement, This seems to work ok as the Sony original is very expensive
FE1 KV25K5U   not starting up, LED flashes 4 times   T511 breaking down at switch on, replace T511 (145326411 for 25", 145326511 for 29")
FE1 KV25K5U   St/by only with error code 2x flashing   In prot mode due to LOPTr Q533 2SD2539 s/c due to dry joints line driver Tx
FE1 KV25K5U   Trips off with a crack - LED flashes 5x   CRT faulty
FE1 KV25R2D   Reverts to st/by with LED flashing x2 in 2 secs   SE135  +B  regulator  diode leaky, also caused demise of FOP chip STV9379
FE1 KV25X5U   comes on then goes off, red LED is on   stby IC609 TOP209P u/c
FE1 KV25X5U   No frame Lock on OSD Menus and teletext   SM cap next to FOP chip had crack across its connection
FE1 KV25X5U   Service Mode   While the set is in standby Press OSD (i+) then 5 then VOL+ then TV ([])
FE1 KV25X5U   To reset EEPROM   select chan 59, enter service mode, at TT-- prompt, enter 49 then 24 (for UK) & 08 then sw off at mains
FE1 KV25X5U   Tripping with LOPTr 2SD2539 s/c   Dry joints line dr trfmr - as orig LOPTr costs £20 - used 2SC4769
FE1 KV25X5U   yellow line down screen about 2 inches from RHS   IC301 CXA2060BS (875208838)
FE1 KV25X5U etc   Enters search mode as soon as its switched on   "replace SS902 preset search switch and clean PCB that it is
mounted in"
FE1 KV29K5U   dead, in stby   C515 220uF 25V s/c
FE1 KV29K5U   no remote operation   D907 BZX79C9V1 leaky on SIRCS line
FE1 KV29K5U   pink band on LHS, only obvious on dark bachground   video lead from CN504 on A PCB to CN704 on CRT wrapped around L537 (LINE LIN), tie bottom edge of loom to the hole provided in top right corner of S PCB
FE1 KV29X5U   Dead with error code 2 flashing   LOPTx HR8520 - use only the top focus control supplied - check for drys on jungle chip
FE1 KV29X5U   Dead with error code 2 flashing & no HT   R613 1R ceramic o/c & STK HT reg s/c - replacement cured - check for drys on jungle chip
FE1 KV29X5U   excessive blue then goes to standby   R722 680k on crt base goes high
FE1 KV29X5U   Int pic - sound ok or nothing with LED flashing 4 times   Dry joint line dr Trfmr T531 (under plastic cradle)
FE1 KV29X5U   no remote, front buttons are Ok   D908 9.1V zener leaky on H board
FE1 KV29X5U   No sigs - ok on scart & OSD OK   IC101 TDA9817 (VIF/SIF Demodulator)
FE1 KV29X5U   Vol OSD perm displayed & front controls give wrong functs   Leaky front control switches - can be cleaned with luck/care
« Reply #23 on: August 17, 2022, 12:17:15 pm »
I was wrong about the B+ being labelled as "200V" on the schematic. I simply mis-interpreted the schematic - that label was referring to another nearby line.
Anyway, I removed Q533 completely, and then tested while measuring B+. Turning the power on, I no longer get the clicking sound, and B+ measured a solid 135V! :D There was no flashing from the standby LED either.
So, is it likely that this was the sole fault? I can buy a replacement S2055N or 2SD2539 for just a few pounds, so I'm willing to try just putting a new one and seeing if that fixes it.
« Reply #24 on: August 17, 2022, 12:21:06 pm »
Thanks, looks like BU2520DF has similar specs and may be another candidate transistor for replacement if I can't get hold of either of the others.
