Author Topic: upgrading HP83620A to a HP83623A  (Read 242 times)
Online pe2benTopic starter
« on: January 30, 2024, 11:13:44 am »
Hello everyone,
Is it possible to upgrade a HP83620A to a HP83623A by only change the amplifier from a HP83623A?
I only need the higher power for driving the MM source modules (HP8355xA series) so i need no external amplifier anymore. The MM sources need +17dBm as minimum input.
Thanks, Ben
« Last Edit: January 30, 2024, 11:17:28 am by pe2ben »
