Not sure where to post this, but I found an electric meter in a dumpster at a construction site that looks like it is in very good condition, but it may need some repair. Coincidentally, I am working on an automated hydroponic and aquaponic system and thought maybe I can use this as a meter to record the power usage of the greenhouse. Potentially, the exact power consumption can be separated from the rest of the property's power usage.
Since this is mains power and I am not an electrician (but I am an architect and engineer), I want to get some idea of whether this is something I am capable of doing. There are two lines going into the greenhouse; one is for the receptacles (20 amps); another is for the lights (15 amps). Is there an easy way to put this in series with both of those lines?
From the pics, it looks like 9, 10, and 11 have the most wear. Ports 9 and 10 still have the copper wire sticking out. It looks like both ports have/had four wires connected. There is a diagram on the front of the meter, but I am not expert enough to know exactly what it means. Would both incoming lines be separated, receptacles and lights (separate live wires and share the neutral) and the outgoing lines sharing those three ports, or do the receptacles get their own two ports and the lights get their own two ports, with the outgoing sharing those four ports?
I am still researching this online looking for a manual, or at least someone's explanation. Thought it would be a good idea to post it here, because you guys are smart and probably can explain it better than any other sources.
Thank You!
edit: I don't know why the forum flips the images upside down. It is very annoying. My apologies.
