I made some progress on it this weekend, but didn't finish. Here's where things are at.
- Got the thermistor installed and measured the R vs T curve.
- Tested the heater.
- Used some potting compound to seal the holes I had to cut to solder the new heater wires to the connector.
- Created an LTSpice model for the heater control circuit (a simple comparator, thermistor, and MOSFET with some supporting circuitry like a 12V linear regulator).
- Removed the no longer needed components from the PD circuit board, and rewired things to source power from 26VAC.
- Replaced DS1 with a red ultra-bright LED and verified it is visible when powered by the rectified 26VAC signal.
- Added some standoffs to hold a little circuit board that will hold my temperature controller and the power MOSFET that switches the heater current.
- Soldered up about 75% of the little protoboard.
During this process I discovered that Q4 is bad. It was right under a hole I was drilling to mount the board, so I checked it with the diode check setting on my meter and discovered open circuit across base-emitter and base-collector. I think this transistor just drives the overcurrent lamp circuit (haven't quite puzzled out the circuit yet, but I suspect it just provides some delay to keep the lamp on long enough to see even if there is just a very brief overcurrent condition). This would explain why this lamp was not lighting when I initially tested the unit. I am planning on replacing this with a 2N5401 that I had in my parts cabinet. It looks to be a fairly close fit.
Also, I discovered that the if I run the heater coil, heating up to a thermistor setting corresponding to 50C, and then cut the power to the heater coil, there is enough thermal inertia to run the thermistor up to a resistance corresponding to around 54C. I have some hysteresis in my controller circuit, but it's sort of a moot point when the temp continues to drift up 4 degrees after power is cut. I am debating moving the thermistor off the circuit board inside the oven, and closer to the oven wall to minimize this effect. Thoughts?
This thing is definitely going to be a Frakenstein's monstor when I am done. And BTW, that Microprocessor-based PID loop makes a lot more sense to me now. It would be about the same component count as what I have now, and would do a better job controlling temps.
