Author Topic: Power Designs TP340A: Repair and facelift  (Read 10545 times)
Offline FlyingHacker
  • You're Doing it Wrong
Re: Power Designs TP340A: Repair and facelift
« Reply #25 on: October 17, 2015, 07:26:16 am »
As a flyer I gotta say, this is no Inverted Jenny!
--73
Online bitseeker
« Reply #26 on: October 17, 2015, 07:34:45 am »
Speaking of which, you can get the $2 commemorative reprint of Inverted Jenny.
https://store.usps.com/store/browse/productDetailSingleSku.jsp?productId=S_580004&categoryId=buy-stamps
I TEA.
Offline Sparky
« Reply #27 on: August 03, 2018, 06:35:17 am »
Pulled the busted 10-turn pot out and installed the new one. Works great and didn't even have to mess with the trim pots. The new pot takes a little more force to rotate, but I think it's better that way. The original ones turn much too easily.
This thread is 3 years old but still a goodie!  I need to replace the Bourns multi-turn pots on a unit I want to restore and I'm glad to read your comment that "the new pot takes a little more force to rotate".
I have a TP340A also...and it's perfectly fine...except one aspect that I find annoying --- the pots turn waaaaay too easily --- the control is extremely "light" (takes no effort) with zero static/dynamic friction of the pot shaft rotating.  I have to delicately let go of the knob when I reach the set voltage to avoid rotating it otherwise I could change the output by several volts!  I also tape down the voltage knobs with painters tape so I don't accidentally knock them when I'm using the power supply...
Do the Bourns pots wear out and they become friction-less?
On my HP 6227B the pots are very firm and you have to rotate them a lot to change even 1V.  I like the precise control without worry of accidental changes.  Anyway to have TP340A voltage control have a similar feel?
Online bitseeker
« Reply #28 on: August 03, 2018, 09:34:54 pm »
You can check datasheets for info on how much torque is required to rotate the wiper. It's among the mechanical specifications. I used a Bourns clone, which is why the feel is different (and I suspect the longevity will be, too).
I've not heard of these things getting easier to turn with age. I suppose it's possible if the wipers and/or shaft wear a lot. The little HP E361xA power supplies I have all use Bourns pots and, despite being newer than the TP340A, also turn with very little torque.
I TEA.
The following users thanked this post: Sparky
Offline Sparky
« Reply #29 on: August 04, 2018, 04:53:20 am »
Thanks for noting that about the torque in the mechanical specs -- I will check it out and probably choose the one with highest torque requirement!
