Hello,
a friend gave me a PD Device, a power distribution from "Z-Line" PC302. It has a three phase input and 14 Outputs (12 switched, 2 unstitched on the back). I opened it and a cable, signaling the main power werde burned. I would like to solve two problems:
1. Repair the burned cable, which is no problem, but find perhaps other failures
2. rebuild the PD so i can serve it with normal current (not three phase, but one). (I though that i could bypass the threepase input and connect the 220V directly, behind the 3-phase converter t use it as a normal 220V power distribution)
