First see pm and photo DC offset explanation.
As a knowledge not related to this part. See below.
DC Offset voltages are between 1.9 mV and 4.8 mV on all channels. Measured with multimeter at speaker outputs (if that hopefully makes sense)
DC offset absolutely normal.
But when it occurs I can quickly lower the master volume from my usual power on volume level of -60 dB to something like -70 dB. Then at startup I can hear a pop noise but the amp does not enter DC protection.
I am sorry to tell you that you meet the most difficult problem: HDMI / decoding board faulty. ALL signal no matter what analog or digital, will be processed by PLD board, then 4 DSPs in your amp and finally converted to analog via DACs then goes to LPF (low pass filter) and amplified by amp section.
But when it occurs it sometimes persists for few minutes. Then I have the pop noise and it goes to protection right at startup when the speaker relays switch.
What else can it be? AVCC+7 / AVCC-7? Some problem with DSPs or DACs or their supplies?
YES, see above, any chips go wrong or software needed in
both PLD and 4DSPs make pop sound.
Why do pop sound cause dc protect?
Due to high volume at first, the sinewave mixed with pop sound makes sinewave be clipped. Clipped sinewave is
dc, triggering dc protection.
Let me guess you maybe always watch blu-ray films at high volume level or place your amp in a hifi cabinet.
You can still try your best to troubleshoot it stage to stagesee pm if you have time. Oscilloscope 40 mHz
is needed. See pm (send you tomorrow) .
You are very unlucky. Never buy amps without usb.
Nor buy marantz or denon due to same digital
board with PLD.
In Hong Kong even authorized service dept. will
Not troubleshoot HDMI board.
customer, cu,: pop sound in amp.
tech: 450HKD inspection fee.
tech: ok, problem found, HDMI board
Cu: how much ?
tech: can‘t repair. Only replacement . 3500HKD
cu: how much? 3500? He go away.
This is how techs scare off customer.
