I try to repair a network camera (Axis Q6032-E) that has died suddenly after more than 10 years of service.
I strongly suspect that the problem is in the Power Over Ethernet power supply board, and more specifically in the flyback converter, since i measure no voltage at the output of the converter.
There is no other way than POE to power the camera.
Visually, i see nothing wrong on the board. The capacitors look good, and their measured value is ok (i have not measured esr).
The power supply is composed of two isolated flyback converters controlled by two NCP1081 (
https://www.onsemi.com/pub/Collateral/NCP1081-D.PDF).
The circuit seems very close to the schematic in figure 2 of the datasheet, except that it uses the extra winding (see figure 4), and two completely separate converters in parallel for data pairs and spare pairs.
I have measured several voltage (DC) at various points of the two NCP1081 (see below), and the results look definitly odd, but i can't understand what is going on exactly.
The measured voltages are the same whether the other boards of the camera are connected or not.
converter 1 (from spare pairs)
VPORTP-VPORTN : 53.8V (ok)
ARTN-VPORTN : 52.2V
VDDH : 1.3V
VDDL : -0.1V
VCpd : 1.6V
converter 2 (from data pairs)
ARTN-VPORTN : ramp down, reset to 53.8V (symetric to VCpd)
VDDH : 0V
VDDL : 0V
VCpd : slowly ramp up to variable voltage (seen up to 42V), go to 0, repeat
Any idea?
Thanks.
