Hi all,
I recently scored a Fluke 8846A off the bay, obviously, in non-working condition.
Upon opening it up, I was greeted with several "beautiful landscapes", the most extensive one being shown in the photo attached.
I would like to bring this meter back to some functioning state, so I've started looking for the components which are most obviously damaged.
Some of them are burnt/damaged beyond recognition, or have simply been vaporized.
But, with the help from TiN's very nice high-res photos from one of his repairs, I was able to build a list of components needing replacement (please see below).
Suffice to say I expect the list to grow as I'm progressing with the investigation, but it's a start.
I know this may be a tall order but, in case someone happens to have another unit opened up, I would appreciate it if they could check & confirm the identification of at least some of the components in the below list.
Also, if someone happens to have a spare Fluke 2464674 resistor network or even an entire board from a broken 8846A, I would be interested.
And here is the list (grouped per proximity of placement on the board):
CR16 - OnSemi BAV99L
R70 - 1kOhm
C67 - ?
U24 - Ti LF353M op-amp
VR4 - OnSemi MMBZ5230BLT1G
R194 - 200 Ohm
K2 - Panasonic/NAIS DS2E-SL2-DC5V relay
Z1 - Fluke 2464674 resistor network
Q25 - OnSemi/Fairchild MMBF4117
CR30 - OnSemi BAV99L
R103 - 100 Ohm
Q54 - OnSemi MMBT3904L
R582 - 100 Ohm
Thanks!
