Hello everyone, i bought another faulty LG Mini Hifi (to salvage the CDPlayer module for my original LG:
here).
But now i just only want to understand what could be wrong with this "other" power supply, nothing visually wrong with it but voltages take a long time to appear at the outputs.
I only found this
service manual and at
page 37 they show all the Power Supplies variants for this LG Model, and this one doesn´t have StandBy Led, so some transistors are not present.
Initially i didn't had any other voltage beside the +5V output, i replaced one transistor (the
Q909 (
S8050 NPN)) and then i have other voltages but all with delay.
I checked this components:
IC901 (DM0365RN) -> Testesd it with another one
IC902 (TL431) -> Testesd it with another one
PC901(OPTO) -> Testesd it with another one
Diodes (
D910,
D908 and
D909)-> All removed and tested, values seems Ok.
THis board have 3 transistors S8050 (Q9009, Q905, Q911) and one B772 (Q908) and replace all with new ones.
Check all the electrolytic capacitors and seems all ok.
But voltages don´t appear without the ~2-3 minutes delay
but then it works all ok.
Any idea what can cause the 'delay'?
