Author Topic: power supply Gossen 44T40R5  (Read 558 times)
Offline repairMatthiasTopic starter
    • Matthias Weissers Infopage
« on: January 16, 2024, 10:19:57 am »
I have a Gossen 44T40R5 built in 1973. Its 0-40V, 0-5A and still seems to work. There are 2 pcbs - regulator board A and may be a preregulator board B. I am searching for a schematic. There also had been a 44T20R10 with 0-20V 0-10A. Any available documentation like user manual, service manual, board layout, adjustment or repair hint for those devices would be helpful and is highly appreciated.
Online inse
Re: power supply Gossen 44T40R5
« Reply #1 on: January 16, 2024, 02:26:30 pm »
Years ago I also had a unit from that product range, the preregulator was kind of exotic, you could hear the current consumption of the load in the PFM/PDM.
Everything was done with transistors, no ICs afair.
Is it the same on yours?
Unfortunately no documentation, possibly I swapped capacitors, gave it away later as it loaded the bench too much.
« Last Edit: January 16, 2024, 04:27:04 pm by inse »
Offline coromonadalix
« Reply #2 on: January 16, 2024, 06:26:35 pm »
from gossen    you wont get far, they are  very secretive for their service manual
you loose nothing to ask them .....  but to get high hopes    sorry
maybe some user manual are floating around ...
some threads elsewhere,  some relations / similarities or not
https://www.mikrocontroller.net/topic/416227#new
https://bama.edebris.com/manuals/unigor/t4
https://www.mikrocontroller.net/topic/500414
https://www.mikrocontroller.net/topic/108881#new
main ic :  maybe an lm723  or the mc1466 ???  or fully transistorized ???
« Last Edit: January 16, 2024, 06:34:44 pm by coromonadalix »
Offline Hamelec
« Reply #3 on: January 16, 2024, 10:05:01 pm »
see pdf, should be helpful.
Pls let me know..
.. pdf removed
« Last Edit: January 22, 2024, 08:43:19 pm by Hamelec »
The following users thanked this post: coromonadalix
Online inse
« Reply #4 on: January 17, 2024, 03:16:25 am »
This is the next generation already, from the 80‘s
Offline Hamelec
« Reply #5 on: January 17, 2024, 08:50:17 am »
Yes, I know. But the next generation could just be a facelift and the circuit could be more or less unchanged.
Have to be checked..
