Author Topic: Power supply K-3206  (Read 5783 times)
Offline mgf897Topic starter
Power supply K-3206
« on: August 05, 2015, 10:59:59 pm »
Does anyone have a copy of the schematics for a K-3206 40V/3A power supply?
I recently bought one used of eBay and would like to check it over. I believe the power supply was originally sold as a kit. Thanks.
Re: Power supply K-3206
« Reply #1 on: August 06, 2015, 01:10:21 pm »
Brand?
Photo, as it might be a re-brand.  :-//
« Reply #2 on: August 07, 2015, 03:13:38 am »
Hi Tautech, it's a dick Smith model. I'll post a picture when I get home.
Offline aargee
« Reply #3 on: August 07, 2015, 06:29:09 am »
It was an Electronics Australia design (Dec '93 / Jan '94). Silicon Chip magazine will have back issue copies.
Not easy, not hard, just need to be incentivised.
Tac Eht Xilef
  • Guest
« Reply #4 on: August 07, 2015, 07:08:53 am »
K3206.zip. Enjoy  ;)
I think it includes the very important errata about the transformer secondary connections - the original overlay / connection diagram had, IIRC, the CT & one side reversed. (From memory it took 12 months or more for EA to post that errata!)
As a general tip: it also benefits from added decoupling, etc. otherwise it's a bit prone to ring/oscillate. I've got a link or list somewhere somewhere which mentions a few mods; I'll try and dig it up post it later.
edit: Thinking back on it, the original overlay / diagram might've had one half of the secondary shorted to the CT/gnd (the schematic was correct). No errata mentioned in my PDF, so you'll have to trace it out yourself (it's pretty obvious). Needless to say, don't power it up without checking that out ;).
Also, the DSE kit supplied a slightly under-spec'd E-core transformer rather than the specified toroid - end result was it had trouble reaching 40v or, if it could, it couldn't supply much current.
And here's the thread on EDAboard where they discuss anti-oscillation fixes/mods.
« Last Edit: August 07, 2015, 07:46:27 am by Tac Eht Xilef »
The following users thanked this post: xavier60
« Reply #5 on: August 07, 2015, 11:08:51 am »
Awesome, thanks tac eth xilef
Offline Webserfer
« Reply #6 on: January 30, 2016, 03:39:28 am »
I know this is over 4 months later but I just got lucky on ebay and got a brand new unopened kit for the power supply if you still need any docs that may of came with it. Was fun to unbox I'll say :P
Offline VK5RC
« Reply #7 on: January 30, 2016, 11:40:56 am »
Now that little puppy served me well for probably the best part of two decades as a quick little power supply, still have it. The only issue I had was it does over heat a bit if you start pushing it on a hot day (and its thermal cut out I set a bit low) and its start up voltage curves aren't fantastic but a great little unit for starters.
The usability of analogue type PSUs are pretty good.
