Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Power supply outputs random voltage
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Power supply outputs random voltage (Read 455 times)
uliano
Regular Contributor
Country:
on:
September 28, 2022, 11:57:36 am »
Suddenly (after maybe some year of NON use) this old PSU got crazy
Often, but non always, more likely on channel 2, the voltage under load is less than programmed even if the drained current is far less than the preset limit.
I have no idea where to start looking to investigate this problem.
Some explicative pics.
Last Edit: September 28, 2022, 01:44:10 pm by uliano
Logged
wraper
Supporter
Country:
Re: Power supply outputs random votage
Reply #1 on:
September 28, 2022, 12:12:22 pm »
Your electronic load could be oscillating. Try adding say 1000uF cap to PSU output.
Last Edit: September 28, 2022, 03:37:16 pm by wraper
Logged
uliano
Regular Contributor
Country:
Reply #2 on:
September 28, 2022, 01:37:16 pm »
I didn't think it was the case as the problem showed up with a real (and very small) load, however
What is worst is that it doesn't even need a load
Logged
Ice-Tea
Super Contributor
Country:
Re: Power supply outputs random voltage
Reply #3 on:
September 28, 2022, 02:44:00 pm »
If memory serves (and that's by no means a guarantee), the polarity protection diode on the outputs is a weak point in these supplies. Wouldn't hurt to check. YMMV, obviously, but it doesn't hurt to check...
Logged
eBay shop with all the gear you need!
Some of the same stuff but cheaper
The cheapest is to browse eBay and DM me.
uliano
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
