Author Topic: Power supply question for pro audio gear  (Read 2133 times)
Offline cfcreativeTopic starter
« on: November 25, 2018, 09:31:13 pm »
Hello. I have an ebay purchase of an audio processor that I am trying to trouble shoot.
The power supply that is used in this unit is called a Nemic Lambda swt30-5ff. I looked up the spec sheet and it says that it can take 115 to 20v in and then output +15, -15, +5,+5 and ground but I am getting nothing.
In the troubleshooting section I read this
Check whether output current are more than minimum output
current.
The output voltage of all channel are stabilized when CH1 (all
model) and CH2 (only SWT30, 40) are more than minimum
output current
and for this unit that is .4 amp for the +15v and .2 amp for the +5v
so is there a way to test this?
Thanks for any responses.
Offline coromonadalix
Re: Power supply question for pro audio gear
« Reply #1 on: November 26, 2018, 01:47:26 am »
pdf : https://www.mouser.com/datasheet/2/400/tdk-lambda_swt-1207355.pdf
It is a 3 output psu, not 4  ??? +5 +15 and - 15 volts
to test the maximum output you could do :  5v at 2 amps is 2.5 ohm load, if you put an 2 ohms load  it should go in overload,  15v at 1 amp is 15 ohms  etc ....  but they have an higher peak current,  you must have the loads slightly lower than the peak values current to trigger an overload or an shutdown if its equiped that way.
« Reply #2 on: November 26, 2018, 05:48:42 am »
I just want to check if it works. Right now when I have it connected to 115v AC I get no output.
« Reply #3 on: November 26, 2018, 08:07:32 am »
they are fused at the input,  you should see somekind of fuse ...
« Reply #4 on: November 26, 2018, 08:17:52 am »
If you read the original post it says that there has to be a small load on the power supply can anyone explain this to me.
Offline PKTKS
  • Country: br
« Reply #5 on: November 26, 2018, 09:16:28 am »
Actually **ALL** SMPS requires  minimum load one way or another
SMPS are damn oscillators - good only inside the proper window
the minimum load is there to fulfill that window
Outside the proper window the SMPS will just go wild
so it also requires some sort of shutdown procedure outside the proper range
BTW thanks for the PDF reference...
They say "flyback" at fixed frequency but not much about the
proper flyback implementation - which makes a hell of a difference
Paul
« Last Edit: November 26, 2018, 09:24:14 am by PKTKS »
« Reply #6 on: November 26, 2018, 11:54:42 am »
I wont argue with PKTKS, but our open frames and closed frame psu(s) like the OP  have somekind of load or an bleeder resistor to empty the output capacitors on the board itself, you can power them and test them without any load on the output, ad they are stable and rock steady.
We have many of them, Condor and Meanwell mostly, from 5vdc up to 54 volts,  none of them needs a load to start, only one of them have a remote power on, if we enable it with an jumper. ?
I ve seen tons of smps, they dont always need a load to sart and run ... the only ones i know know to do that are the computers and servers power supply (ies)
You have many topologies  to implement an smps, buck boost, fixed or variable frequency (ies)   etc ....  it depend on the design you need or use  i may say.
Edit : i have at home, Corsair and Thermaltake psu, they start without the mobo or any hard drive on them,  just need to short the power signal on the 24 pins plug.
« Last Edit: November 26, 2018, 11:56:55 am by coromonadalix »
Offline PKTKS
  • Country: br
« Reply #7 on: November 26, 2018, 01:19:35 pm »
No no no nothing to argue.. not even disagree.
In fact no SMPS requires the load to start or function..
the matter is REGULATION.
When you do the math on inductors caps and MIN/MAX load regulation
you almost certainly will have that "range" for regulation
Please don't insert a uP on the thing - which will  change things
on the fly..   Just bare bones SMPS and load regulation
Similar math we do on Linear but it just affects limits of stability
and poor regulation, may be high freq oscillation
We now have uP controlled SMPS which can change inner passive
parameter (aka  reflected impedances) on the fly
Much more complicated and still subject to line regulation issues
Some recent books i've seen devoted chapters to the so called
resonant energy  by impedance match... or smps resonators
The more you add this issue the better - with no argue as any (hundreds
of them) books on SMPS put chapters devoted to minimal load
and regulation
Paul
« Last Edit: November 26, 2018, 01:24:02 pm by PKTKS »
Offline commongrounder
« Reply #8 on: November 26, 2018, 03:17:08 pm »
Based on the info the OP supplied, I would disconnect the preamp circuitry from the power supply, and attach a 22-ohm 1 watt (or larger) resistor across the +5 volt supply, and a 33-ohm 10 watt resistor across the +15 volt supply.  If it is working normally, it should power up and stabilize to the nominal voltages on each rail. If it doesn’t, check the caps (the new rallying cry of servicers everywhere!). There is also a possibility of a problem with the pre-amp circuitry dragging down one of the rails, so divide and conquer!
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #9 on: November 26, 2018, 04:19:24 pm »
Pro Audio gear is using switching PSUs ?!?
Naah.
« Reply #10 on: November 26, 2018, 05:59:52 pm »
Naah.
Absolutely yes!  I see it all the time.  It’s even more common now that digital power amplifiers are available. Efficiency and light weight are big selling points.
Seriously, though, it is quite normal to see high quality switchers used in high-end consumer audio equipment, as well as the professional stuff.
Offline Wolfgang
« Reply #11 on: November 26, 2018, 06:32:28 pm »
what kind of equipment are you referring to ?
« Reply #12 on: November 26, 2018, 07:50:32 pm »
Are you asking about types of equipment, or specific brands and models?
Don’t want to veer too far off the OP topic.
« Last Edit: November 26, 2018, 07:52:17 pm by commongrounder »
Offline Wolfgang
« Reply #13 on: November 26, 2018, 07:54:29 pm »
Specific brand and models, please.
Offline Richard Crowley
  • KJ7YLK
« Reply #14 on: November 26, 2018, 08:02:33 pm »
According to the published data sheet:  https://product.tdk.com/info/en/documents/spec/swt30_spc.pdf
That model has a MINIMUM load requirement of 200mA @ 5V and 400mA @ 15V
I wouldn't attach an unknown (either new or used) power supply to my circuit without testing it first with a dummy load.
  • KJ7YLK
« Reply #15 on: November 26, 2018, 08:04:23 pm »
Waaay too many to enumerate.
Even highest-end ultra-pro analog audio gear is found with SMPS.
People stopped complaining about that years ago.
Nothing wrong with SMPS when the system is designed properly.
« Last Edit: November 26, 2018, 08:11:03 pm by Richard Crowley »
« Reply #16 on: November 26, 2018, 08:05:52 pm »
Thanks common grounder I will try this. Mouser categorizes it in "switching power supplies"
Here is the PDF link for more info https://www.mouser.ca/datasheet/2/400/tdk-lambda_swt-1207355.pdf
« Reply #17 on: November 26, 2018, 08:08:38 pm »
So where the power supply connects to the board I can put a meter across from the 15v connector and to ground and I can see what load it is to see if the fault is on that side?
  • KJ7YLK
« Reply #18 on: November 26, 2018, 08:16:39 pm »
You can measure the VOLTAGE output from each of the three outputs relative to ground by probing with your meter in voltage mode. That appears to be what you are already doing.
If you want to measure CURRENT on each of the outputs (one at a time unless you have three meters) you must put the meter (and the test leads) into CURRENT mode and connect the meter in SERIES between the power supply and the load (replacing the wire).
