Hello, I am learning to repair electronics devices and I came across simple design power supply from mobile air conditioner.
Power supply takes mains AC Voltage and turns it into 12v/5v. 5v is used for device screen, while 12v is used for turning relays on/off for motors.
Things that I tried/know:
0 Visually there is no burnt components
1 Fuse and bridge rectifier is good - main caps have 300+ DC voltage
2 "low side" of power supply seems to have no shorts/problems - if i inject needed low voltages with external power supply directly into the capacitors, device works perfect
3 Measured electrolytic capacitors, resistors, diodes - nothing to be out of spec
4 Transformer seems to have continuity on each side (as expected). There is no continuity from high side to low side
5 Tried changing IC THX202H => THX203 (Aliexpress sent me wrong one)
6 Tried changing 817B from other circuit board
After all these steps power supply still has 0v at output
Looking for some tips on how can i troubleshoot it further. Adding images of back and front of the power supply.
