I have a power supply ( PS2494-YE REV. C1, D2 ) which was hit by a surge, it damaged a number of components.
I've replaced all the components which were obviously damaged but I am unsure what the value of two are because they are so badly damaged.
I haven't been able to find any docs or schematics on the board so I am unsure the best way to approach working out what they need to be replaced with.
Does anyone have any recommendations?
Components that look the same with different values.
I can't find any reference online to the "P1 E9" which makes it even more difficult to find what one of the damaged ones is.
I assume these are resistors but I haven't seen green ones before.
IN 220-660VAC, 50/60HZ, 16.0A
OUT 30-600VDC @ 13.2A 8KW
