Remember old capacitors have a much wider tolerance than modern ones, usually something like -20%, +50% or even +100%.
These days they have the processes perfected, to produce them nearer the bottom end of -10% tolerance, to minimise materials used & maximise profits.
Also note measurements on old stuff, should be taken after they have had a chance to reform and heat from soldering can temporarily affect the readings obtained.
