This is branching from my Dana voltmeter repair thread. I figure a separate thread may garner more attention.
The transformer is heating up which has lead me to look into the PSU and loads. The entire meter draws roughly 50 watts or so, which is actually 10 watts LESS than a similar unit (Dana 5500).
I believe I have a problem with the 300v rail in the schematic below. I have tested C7, it reads 60uf .7 esr or so. CR3-4 and 13-14 test OK in circuit. C5 is at least not shorted, but I have not tested it out of circuit. R1 reads 210K or so.
Here is the unloaded wave form of the 300v rail, looks ok to me.
Here is the 300v rail wave form under load I think it is drawing in the neighborhood of 20 watts, perhaps a bit less.
My understanding is this drastic change in the wave for can be either a filter cap issue or a load issue. I am wondering if anyone here can tell by these wave forms which of the two it might be?
