Author Topic: Power Supply wont turn on  (Read 1774 times)
Offline synth-dudeTopic starter
« on: January 30, 2016, 05:42:18 am »
I pulled a power supply from an old TV, its capable of delivering a few amps supply so thought I could use it as a secondary bench supply.
Problem is is doesnt turn on unless it receives a signal to do so, its microcontroller controlled.
Just wondering if there is a common way these are activated?
Attachment is the board if it helps.
Thanks
Offline retiredcaps
Re: Power Supply wont turn on
« Reply #1 on: January 30, 2016, 05:50:32 am »
On the connector to the main board, look for a pin labelled PS_ON.  It usually needs to be > 3V in order for the power supply to come on.  You can trying tying a 1k ohm resistor between 5V standby to PS_ON.
If this is an older plasma TV power supply, you may need more than just PS_ON.
« Reply #2 on: January 30, 2016, 09:17:37 am »
Thanks for the response.  Unfortunately I dont have the main board any more.  Is there a way to work out which pin it might have been?  I could always just try each one with the 5v standby voltage and see what happens.
Offline tyguy2
« Reply #3 on: February 03, 2016, 08:03:45 pm »
That wouldn't be a good idea, you could short something important. I would look up pinouts online.
[Sarcastic comment] clever joke [/sarcastic comment]
Bitcoin:
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
