Author Topic: Power Switch (table saw) with one way turning screws? (how to open)  (Read 1831 times)
Offline onesixrightTopic starter
Hi All,
I need to replace the power cable of this switch. Its from a table saw, but as you can see on the picture the screws turn only one way (I think)  :wtf:
I can order a complete new unit (E 80), but only the cable is broken (E 6)  |O
Anybody a clever idea how to deal with this ? And I don't mean cutting the cable :-) and put a new connector on it..
I would like to replace the whole cable from the socket into the box.
Thanks!
Offline Monkeh
Re: Power Switch (table saw) with one way turning screws? (how to open)
« Reply #1 on: June 24, 2018, 03:01:25 pm »
Usually you just press harder to stop the screwdriver sliding off...
Alternatively, just cut a slot in them.
The following users thanked this post: onesixright
Offline cheeseit
« Reply #2 on: June 24, 2018, 03:24:34 pm »
Or use locking pliers/vise-grip to remove them, then throw them away and replace with something sane.
Online BradC
« Reply #3 on: June 24, 2018, 03:59:42 pm »
If the other good and easier suggestions fail, I'd drill a hole in each and use a left hand extractor (like an ez-out). Failing that, a left hand drill bit. If that fails and it's not surrounded by plastic then I'd TIG a bolt to the head of each screw and back it out with a socket. The heat of the TIG loosens it up nicely.
« Last Edit: June 24, 2018, 04:36:22 pm by BradC »
Offline alpher
Offline james_s
« Reply #5 on: June 24, 2018, 04:05:56 pm »
If the heads protrude above the surface you can file a slot in them to use a standard screwdriver.
Offline Monkeh
Offline james_s
« Reply #7 on: June 24, 2018, 04:22:57 pm »
If you're paying an employee to do work that requires occasional removal of such screws, $20 for a tool that makes it easier is a bargain. Sure for someone who only needs to do it once there are other ways but if I regularly encountered 1-way screws I'd buy a set of those tools.
Offline nanofrog
« Reply #8 on: June 24, 2018, 04:26:13 pm »
https://www.mcmaster.com/#one-way-screw-remover-screwdriver-bits/=1dfb9l1
Trust McMaster to have a $20 solution to a $0 problem!
They'd be useful in paid jobs.  Removing bathroom partitions in public restrooms for example (remodel).
Edit: james_s beat me to it.  ;D
« Reply #9 on: June 24, 2018, 08:27:13 pm »
Thanks all!
Sent from my iPhone using Tapatalk
Offline ignator
« Reply #10 on: June 25, 2018, 02:09:32 am »
I would use a Dremel tool with a cutoff blade, and grind a standard screwdriver slot. I didn't see that suggestion.
