Hello all,
I'm trying to repair my old bass amplifier, the power amplifier works as intended when loaded by 10Ohm at more than 100Wrms, exepting that a quite loud whistle can be heard when the signal is 8kHz or more. And the whistling freq heards like it follows the signal freq.
1st I've think about the transformer (but if it was the culprit, the whistle should be 50Hz, right ?), but tighten the screws that "close the EI" does not change anything. Then I was thinking about the power resistor, after all it looks like a coil inside. But there again, it wasn't the guilty.
I've extended the cabling to use the amp PCB outside the chassis, and now I'm sure the whistle come from the PCB... but there is no coil nor transformer on it ! The only components that can see high currents are the power mosfets in TO3 case.
So my questions are:
- is it possible for power mosfets to whistle ?
- if a power mosfet whistle, is it a bad sign regarding mosfet EOL or other ? (if the whistle is at the same freq that the signal, I guess it won't harm that much at 180Wrm when the load will be a speaker !)
- any advice to localise the whistler ? the board is something like 200mmx50mm, and touching some parts (especially mosfet and their rad) do nothing on the noise.
I can post a picture of the PCB/amplifier and/or its schematic if it helps. Not sure about the schem copyright, but google with trace elliott GP11 will easily find it.
Last: this is my 1st post there, and i'm not a "forum guy", in fact this is my 2nd forum ever... Sorry for any awkwardness.
Thank you
