[/quote]
Thanks @Audiorepair. I'll do that.
Can I ask why C13?
[/quote]
Because you seem to think there may be a dc problem, and this point sets the DC gain.
Likewise you could change C17 and C9, as electrolytics are well known to go bad, and it is cheap and easy to replace 3 of them to rule them out, as you currently have no real data to go on as to what is going on.
While you are fault finding, I would remove the mute JFet Q1, it is very common for these Fets or the mute circuit itself to go partly faulty.
(The electrolytic C8A would be a prime candidate for this)
