I am doing a teardown of a Powerland 48V Li Battery Charger.
The Charger contains a MC9S08PA4 which I assume is the charging controller.
I have traced connections from to battery connector back to Pins 7 & 9 of the MC9S08PA4.
Can anyone suggest the type of signals I should measure on these pins as I can only measure DC Voltages at the battery connector?
