Hi, well I am trying to learn along the way here too, this is my first attempt of trying to do this. Being I had the unit totally taken apart, I thought I'd try to get the IF transformers close before installing, thinking it will get them close?
I have not been able to get my AWG to work (yet), maybe I am not supplying enough voltage to the IF coil (I cannot get any adjustment). AWG has 50ohm inputs. I been able to get my old B&K E-220D to work and also my old function generator to work. Both have 50ohm inputs. Scope I am using has 1M inputs. I did put a 1k ohm resistor on the input side from the generator.
So what I did is not close? Seems like the screws are close to where they were. Appreciate everyone's help. Thanks.
Edit - just got my AWG to work, I been inputting the wrong frequency in
