Author Topic: Preheat temp setting duration when using AOYUE (etc.) 853A rework pre-heater  (Read 1385 times)
Offline wb0gazTopic starter
Need to handle a small reflow task (this isn't a repair task, but this kind of requirement probably comes up during repair so thought i'd start here.)
I'm going to use an Aoyue (etc.) 853A rework pre-heating unit before hot air soldering.
Any guidance available on what temperature preset and pre-heat duration I should use?
Any guidance available on what workpiece temperature I should measure before using hot air to reflow?
Would a Flir-type IR imager be sufficient to measure temp of the workpiece?
Solder will be either 63/37 PbSn or 57Bi42Sn1Ag paste. The workpiece is small FR4 PCB.
Thanks  for any advice (or pointers to information on this topic.)
Offline BreakingOhmsLaw
  • Certified solder fume addict
Don't bother measuring the temperature, you don't need rocket science precision here.
I preheat to 125°C on lead free PCB and then spot-heat the areas of interest with hot air set to 360.
If you used Bismuth tin, you'll need to drop the temperature to 90 plate /145 air.
Don't throw the PCB on the already heated hot plate, start with a cold(ish) plate to reduce thermal stress.
Hello BreakingOhmsLaw, that is very much helpful!
1. I will begin from cold start on device, with workpiece already placed.
2. Shall I set pre-heat machine temperature (it's set-point for radiated heat) to 125C? For this pre-heat machine, there is ~2cm distance from thermal element (below) to workpiece (above), suspended by metal structure to keep PCB away from thermal element.
3. How long should I wait (once pre-heat machine reaches set point, until workpiece reaches OK temperature?
Thank you again!
Offline Silicium81
    • Technical forum
Hello,
I have a YIHUA 853A preheat unit. To get the PCB to 100°C, I need to set the heater temperature to 250°C. The safest thing is to measure the temperature of the PCB with a thermocouple!
Electronic engineer with a passion for mechanics
https://vae-tech.forumactif.org/
That (preheat setting) was what I was completely uncertain about.
What do you use for a thermocouple, and how do you apply it for this purpose?
Thanks!
Offline Silicium81
    • Technical forum
The thermocouple bracket:
In fact, I made a small system to be able to remove the BGA (and put them back after reballing). The thermocouple is used to regulate the upper circuit temperature by generating a controlled reflow profile. But before starting the upper heating, it indicates the temperature due to the lower heating.
https://vae-tech.forumactif.org/t239-reparation-bga-ou-rebillage (in french  :palm:)
(sorry for my english 'google translate'  :'( )
Thank you excellent detail!
Hope for BGA in future!!!
Now I will find DMM + Thermocouple solution.
Thank you again,
Dave
Offline Silicium81
    • Technical forum
Thank's, For low price thermometer with thermocouple, search TM-902C on aliexpress  ;)
Thanks so much, Silicium81!
I had searched unsuccessfully for that sort of device, evidently wrong search terms.
Order now placed.
Very much appreciate your helpful detail - this is how to solve the requirement!
Dave
Offline testpoint1
Thank you again,
Dave
Fluke 87V and 80BK-A probe
Rats - I knew i had a thermocouple probe somewhere, came with a DMM, long since lost...
Oh well, that's a helpful pointer!
Dave
