Hello BreakingOhmsLaw, that is very much helpful!
1. I will begin from cold start on device, with workpiece already placed.
2. Shall I set pre-heat machine temperature (it's set-point for radiated heat) to 125C? For this pre-heat machine, there is ~2cm distance from thermal element (below) to workpiece (above), suspended by metal structure to keep PCB away from thermal element.
3. How long should I wait (once pre-heat machine reaches set point, until workpiece reaches OK temperature?
Thank you again!
