Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Printer - Brother 110 Laserprinter
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Printer - Brother 110 Laserprinter (Read 2529 times)
anishkgt
Frequent Contributor
Country:
on:
January 16, 2017, 04:39:00 pm »
Hi All,
Am trying to test this board of a Brother Laser printer 1110. Would the
heat-on
on
pin 3
switch ON the heating drum, if connected to GND on the board ?
Logged
Cupcakus
Contributor
Country:
Re: Printer - Brother 110 Laserprinter
Reply #1 on:
January 17, 2017, 07:49:01 am »
Without a schematic I'm not sure how helpful I can be, but I've worked on a fair share of laser printers... You can be sure a relay of some sort turns on the fuser filament, is there voltage on heat-on?
Logged
anishkgt
Country:
Reply #2 on:
January 17, 2017, 07:50:20 am »
Thank cupcakus! Yes there is it is pin 3
Sent from my iPhone using Tapatalk
Logged
Cupcakus
Contributor
Country:
Reply #3 on:
January 17, 2017, 07:58:49 am »
Well I'd briefly connect it to ground and if you hear a relay switch you have your answer. Not knowing this printer I would not run it like that for any length of time. Be very careful, high voltage will be present.
Logged
xavier60
Super Contributor
Country:
Reply #4 on:
January 17, 2017, 09:24:36 am »
Looks like there is a triac on the live side, and likely to be driven by some sort of opto-coupler. Then I wonder what the relay is for.
Last Edit: January 17, 2017, 09:27:29 am by xavier60
Logged
HP 54645A dso, Fluke 87V dmm, Agilent U8002A psu, FY6600 function gen, Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
anishkgt
Country:
Reply #5 on:
January 17, 2017, 09:25:07 am »
Yea I guess will just quickly connect the relay on pin and heat-ON on
Logged
anishkgt
Country:
Reply #6 on:
January 17, 2017, 09:35:58 am »
Yea there is one, am guessing that is controlled by pin 3 shown in the second pic.
Logged
xavier60
Super Contributor
Country:
Reply #7 on:
January 17, 2017, 09:43:54 am »
Voltage must not be applied directly to the LED side of opto-couplers, there needs to be a current setting resistor in series.
Logged
anishkgt
Country:
Reply #8 on:
January 17, 2017, 09:45:27 am »
Not sure if the opto has anything to do here. Will have to see how pins 2 and 3 works when connected to GND.
Logged
jdraughn
Regular Contributor
Reply #9 on:
January 17, 2017, 01:27:37 pm »
I would measure resistance between that pin and gnd, and that pin and logic voltage to see if it's pulled up or pulled down.
Logged
anishkgt
Country:
Reply #10 on:
January 17, 2017, 04:11:30 pm »
Would the logic voltage be 5 ?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
