Hello PiotrMisiuna,
Great to hear that the elevator door is now fully functionnal
Thanks for the documentation.
You may now edit the title of this thread by adding the word that everyone wants to see in the repair section of the forum : '[SOLVED]'
The elevator guy wasn't too happy.For him, it's of course easier to litter the defective assembly and install a brand new one, problem solved.
I would say that for sustainability reasons, we will probably need to make more 'component level' repairs in the future. With more and more boards that are fully populated with SMD parts, it's not an easy challenge. And without any schematic as for your elevator door board, it is even more demanding.
I didn't expect it to be placed in such idiotic place. Right above the door with all the connectors facing upwards. Wash the floor one level up and spill more water..... you know.Well, at a certain level of nonsense, you can't exclude that the board was strategically installed at this location so that water spilling from the above floor just drops at the right place to fry the assembly
. You mentionned in an earlier post that the cost of a replacement board was really high. No real need to look anyware else.
To avoid future hassle, consider protecting the electronic assembly with a plastic bag hold by some duct tape. Using a
mylar/plastic sheet to build a small roof above the assembly might be another solution. Stick the plastic sheet with strong
epoxy glue.
