Author Topic: Prisma elevator door controller, damaged psu, need identify components[SOLVED]  (Read 3899 times)
Offline PiotrMisiunaTopic starter
  • Country: cy
Could not locate any photos of the PCB, attaching best I could make, maybe will help someone else.
There is several versions of the box but I don't believe they will differ much in layout, especially on the primary side of the psu.
 Killed by a drop of water, I did some reverse engineering, but with my low experience I don't believe I can make it without help.
Components on the schematic marked in red are the damaged ones.
Seams obvious that all the carnage was caused by arc under the C37.
I hope that blown components broke the circuit before melting the transformer, it does not appear to me melted.
Not sure how to determine the value of the Z7 zener diode...
list of components I wish to find markings for:
R114
Q32
Z7
R85
U10
« Last Edit: February 02, 2025, 09:44:22 pm by PiotrMisiuna »
Offline fzabkar
Offline Harry_22
Re: Prisma elevator door controller, damaged psu, need identify components
« Reply #2 on: December 03, 2024, 06:05:34 am »
Well, finally! One person who got together and redrew the circuit from the PCB.
 It will be a pleasure to help you!
 I'll take a look a little later.
Offline Harry_22
« Reply #3 on: December 03, 2024, 10:42:21 pm »
Hi!
Could you carefully clean R114 and try to read the color code.
Also make a good photo of Q32, U10 area.
  • Country: cy
« Reply #4 on: December 04, 2024, 04:20:35 am »
R114 has the bands visible on the other side but I think the paint pealed off due to temperature and what's left is just a discolored substrate.
Offline Harry_22
« Reply #5 on: December 04, 2024, 05:07:45 pm »
Check Z13, Z14 for short and open.
I don't like that the base Q32 is connected only Z14.
Please measure C56.
Offline fzabkar
« Reply #6 on: December 04, 2024, 05:23:51 pm »
Q32 doesn't make any sense to me, nor does the feedback circuit involving the optocoupler.
  • Country: cy
« Reply #7 on: December 04, 2024, 07:18:29 pm »
Z13 and Z14 open circuit, tested out of circuit.
R112 - 10K,
C56  - 2,4nF
did some edits following your order
third attachment is just a back lit photo of the pcb, maybe useful.
  • Country: cy
« Reply #8 on: December 04, 2024, 07:21:39 pm »
Did some corrections to the schematic.
As to the optocouppler, I believe it is just a voltage sense for a controller. Tracks disappear under the row of sockets and run deep into secondary side.
Offline fzabkar
« Reply #9 on: December 04, 2024, 08:21:06 pm »
The Vcc pin needs to charge up to 16V before the IC starts pulsing the MOSFET. I don't see any path for this charging current.
Z7 must be a Schottky diode.
Why is the base of BC807 grounded?
« Last Edit: December 04, 2024, 08:27:46 pm by fzabkar »
Offline DavidAlfa
« Reply #10 on: December 04, 2024, 08:54:09 pm »
Weird circuitry around Q32.
Normally Vcc is directy feed from HV (Yeah, 300V++) through a 200K-1M resistor.
This greatly limits the current, so the Vcc capacitor charges slowly.
When reachingthe threshold voltage the PWM IC will turn on, pulsing the driving transistor, and start feeding itself though the auxiliary winding.
Offline Grandchuck
« Reply #11 on: December 04, 2024, 09:01:23 pm »
Did U10 pop part of its top off?
  • Country: cy
« Reply #12 on: December 04, 2024, 10:04:35 pm »
U10 did popped a piece of i
t.
More corrections. it gets better once the shorts get removed. BC807 was also shorted
Offline timeandfrequency
« Reply #13 on: December 04, 2024, 10:22:06 pm »
Hello PiotrMisiuna,
Nice holes in U10 & Q32 : 'magic smoke' generators :P
Your latest schematic starts to match with the UC3842 reference design (figure 8-2)
Opto on the right of your schematic is for the SMPS feedback : you should also find a TL431 in that area.
Opto on the left of your schematic is probably for checking the mains presence or grabbing 50/60 Hz synchronization ticks : is it connected to the Fujitsu µC located on the far right side of the PCB ?
« Last Edit: December 04, 2024, 10:52:12 pm by timeandfrequency »
The following users thanked this post: PiotrMisiuna
  • Country: cy
« Reply #14 on: December 04, 2024, 11:00:02 pm »
Yes, the opto on the left goes to the large Fujitsu. Above it there is a motorola Eprom. There is also a MAX 232 next to the DE9 port. There is really not that much stuff on this board, and the service guys ask  long waiting time and a small  fortune for the replacement.
Offline Harry_22
« Reply #15 on: December 05, 2024, 03:14:09 pm »
The oscillator frequency according to ST datasheet is around 90kHz.
Two chips are currently under consideration:
UC3842B max 100% Duty Cycle/ 90kHz drive operation frequency
UC3844B  max 50% Duty Cycle/ 45kHz drive operation frequency
« Reply #16 on: December 05, 2024, 05:12:36 pm »
Might be high voltage zeners (tens of volts), even if one junction drop should be found in one way : any marking on them ?
Package is known as 'melf' https://services.taiwansemi.com/storage/resources/datasheet/ZM4728A%20SERIES_E2301.pdf
and wattage seems to be 1W  https://www.mouser.fr/c/semiconductors/discrete-semiconductors/diodes-rectifiers/zener-diodes/?mounting%20style=SMD%2FSMT&package%20%2F%20case=MELF
Check if your parts size correspond to a 1 W zener in melf package.
The circuit around Q32, Z13 and Z14 needs more attention/refinement, because it goes beyond the application note.
On this page :
- Figure 5 gives interesting information about the required voltage to power the UC3842, but this will be useful later.
- Figure 6 explains how most SMPS controllers like the UC3842 are powered : startup power comes from the mains DC rail (about 324 VDC in Europe) via 'Rin'. Once running, an auxiliary winding 'Waux' provides power through D1.
Let's go back to your latest schematic.
The 'aux winding' is present and the main power for U10 comes from D12, and this seems OK.
R114 is probably 'Rin' and even if the paint is peeled off, the value you measured (100 k) is probably correct, because the UC3842 asks for at least 1 mA to wake up.
Additionnal information : at 100k, the current is around 3.1 to 3.2 mA, which is more than enough to wake up the PWM controller.
R114 seems to be a 2W resistor. However, it is wise to replace the part with a new one.
Two chips are currently under consideration :
You are right, and to solve the riddle, the transformer ratio and primary inductance is probably required  :palm:
« Last Edit: December 06, 2024, 08:58:19 am by timeandfrequency »
Offline Harry_22
« Reply #17 on: December 05, 2024, 09:52:06 pm »
Please check the both zener connection.
PS
Seems they are the same 18-20V to get 17.3-19.3 start at Vcc.
« Last Edit: December 05, 2024, 10:01:13 pm by Harry_22 »
  • Country: cy
« Reply #18 on: December 05, 2024, 10:25:56 pm »
 :palm: yes, you are correct. I need to stop making this edits at 1:00am.
as to the transformer, it has a sticker, no meaningful results in the search engines thou.
markings at the top just refer to the type of the core.
« Reply #19 on: December 05, 2024, 10:38:02 pm »
Yes it is for sure a custom made part and we won't find any datasheet.
If we really need to know the transformers' ratio and primary inductance to validate the PWM controller reference, those intrinsic parameters have to be measured... :scared:
Offline Harry_22
« Reply #20 on: December 05, 2024, 10:45:09 pm »
Some more thoughts.
There is no point in installing Q32 just to start the controller.
Most likely something else is being powered there, take a look.
If transistor Q32 is shorted on all pins then it is most likely a MOSFET.
Resistor R114 is marked with the first brown stripe, please check it. I set it to 100k but when applying high tension it will not burn like that. Looks like he's about 10 kilos.
Offline Harry_22
« Reply #21 on: December 07, 2024, 06:44:44 pm »
I corrected the circuit digram.
Due wake up resistor is replaced here by stabilized power supply on Q32 the controller should be with lower start threshold i.e. UC3843 or UC3845.
Seems all the zener diodes Z1,Z4, Z7, Z13 and Z14 are the same.
« Last Edit: December 08, 2024, 01:09:14 pm by Harry_22 »
  • Country: cy
« Reply #22 on: December 08, 2024, 09:48:46 am »
I'm ordering the parts. it will take a while, Cyprus shipping is like 3 times the usual. I'll share results as soon as possible.
Offline Harry_22
« Reply #23 on: December 08, 2024, 11:02:32 am »
Yes, life is't easy for you :)
Offline Greybeard
« Reply #24 on: December 08, 2024, 01:13:46 pm »
Don't forget to replace the blue bulged electrolytic cap.
Offline Harry_22
« Reply #25 on: December 08, 2024, 02:00:15 pm »
Zeners can be 13 volts. This is enough to start the controller (Vcc=9V max).
The main thing is that after start-up Vcc voltage rises slightly (up to 10-11 volts) and turns off Q32.
« Reply #26 on: December 08, 2024, 08:56:32 pm »
Buy also a replacement for R114 (100 k).
10 k seems pretty low (lead to a start current of  I = 31 mA)
If the controller does not start with 100 k, you can still try 10 k in a second attempt.
« Last Edit: December 08, 2024, 08:58:49 pm by timeandfrequency »
Offline Harry_22
« Reply #27 on: December 08, 2024, 09:48:04 pm »
100k resistor will not burn out as much as 10k in case of Q32 short.
« Reply #28 on: December 08, 2024, 10:09:32 pm »
I already noticed your explanation above.
Let me just allow to have different opinion than yours.
« Last Edit: December 08, 2024, 10:11:50 pm by timeandfrequency »
The following users thanked this post: Harry_22
Offline Poroit
« Reply #29 on: December 09, 2024, 05:40:24 am »
G'day All,
I am not sure if the attached is a help or a hinderance but it contains similar components to the damaged PSU.
I have seen similar damaged components in these as well.
I do not have a schematic.
Offline Harry_22
« Reply #30 on: December 09, 2024, 10:42:54 am »
G'day All,
Hi Poroit!
Yes, yours PSU is mostly similar.
PFC provides its own Vcc supply. That is why low power start-up UCx845 is used there.
Also 50% duty cycle is usually used with the high power transformer.
« Reply #31 on: December 09, 2024, 09:20:45 pm »
Hello Poroit,
G'day All,
Can you confirm that the document you provided shows an elevator door controller from Prisma ?
« Reply #32 on: December 09, 2024, 09:34:29 pm »
About Z14  (Vz = 11 V in the latest schematic)
@PiotrMisiuna Any marking on the zeners ?
Minimum PWM controller startup voltage depends on IC reference :
UC3842 &  UC3844 : 16 VDC   :  Z14 value is underrated, PWM controller will not start
UC3843  &  UC3845  : 8,4 VDC  : Z14  value is OK
Interesting sentence in chapter '7.3.5 Undervoltage Lockout' of the datasheet :
During normal circuit operation, VCC is developed from auxiliary winding NA with DBIAS
and CVCC. At start-up, however, CVCC must be charged to 16 V (*) through RSTART. With a start-up current of 1 mA,
RSTART can be as large as 100 kΩ and still charge CVCC when VAC = 90 V RMS (low line). Power dissipation in
RSTART is then be less than 350 mW even under high line (VAC= 130 V RMS) conditions.
(*) Actual minimal startup voltage depends on IC model, see above.
Reminder : as PiotrMisiuna is located in Europe, VAC = 240 V RMS @ 50Hz (hence DC rail voltage = 339 VDC)
« Last Edit: December 10, 2024, 09:39:38 am by timeandfrequency »
Offline Poroit
« Reply #33 on: December 10, 2024, 05:36:16 am »
G'day timeandfrequency,
Unfortunately not.
It is an SMPS from a 25 year old Air Data Test Set.
The following users thanked this post: timeandfrequency
« Reply #34 on: December 10, 2024, 09:47:25 am »
Unfortunately not.
Thanks Poroit for this information.
These UCx84x switchers have numerous applications and were used in many different designs.
This thread is about the repair of a 'Prisma elevator door controller'.
Unfortunately, the board you showed can not really be used as reference to identify the fried parts we have on that elevator controller.
« Last Edit: December 10, 2024, 01:01:41 pm by timeandfrequency »
The following users thanked this post: Poroit
  • Country: cy
« Reply #35 on: January 18, 2025, 08:42:28 pm »
I believe the repair is successful. Powered up on the workbench effected in one of  LED lights going red and some relays going click.  Now I will pass it and wait for feedback from the elevator technician.  :)
The following users thanked this post: timeandfrequency, Harry_22, Poroit
« Reply #36 on: January 19, 2025, 10:58:08 am »
That's good news.
Keep us updated.
If possible, post again the latest version of the schematics, with the actual parts values/references you used to repair the board.
  • Country: cy
« Reply #37 on: February 02, 2025, 07:28:55 pm »
Ok, controller installed. I didn't expect it to be placed in such idiotic place. Right above the door with all the connectors facing upwards. Wash the floor one level up and spill more water..... you know.  Elevator guy wasn't to happy, but we installed it, tested and it works as supposed to.  I found a manual in the shaft so I got it  scanned. I skipped introduction and table of contents. Attached.
schematic I followed is like in this response https://www.eevblog.com/forum/repair/prisma-elevator-door-controller-damaged-psu-need-identify-components/msg5739749/#msg5739749
« Reply #38 on: February 02, 2025, 09:29:04 pm »
Hello PiotrMisiuna,
Great to hear that the elevator door is now fully functionnal :-+.
Thanks for the documentation.
You may now edit the title of this thread by adding the word that everyone wants to see in the repair section of the forum : '[SOLVED]'
The elevator guy wasn't too happy.
For him, it's of course easier to litter the defective assembly and install a brand new one, problem solved.
I would say that for sustainability reasons, we will probably need to make more 'component level' repairs in the future. With more and more boards that are fully populated with SMD parts, it's not an easy challenge. And without any schematic as for your elevator door board, it is even more demanding.
Well, at a certain level of nonsense, you can't exclude that the board was strategically installed at this location so that water spilling from the above floor just drops at the right place to fry the assembly |O. You mentionned in an earlier post that the cost of a replacement board was really high. No real need to look anyware else.
To avoid future hassle, consider protecting the electronic assembly with a plastic bag hold by some duct tape. Using a mylar/plastic sheet to build a small roof above the assembly might be another solution. Stick the plastic sheet with strong epoxy glue.
  • Country: cy
Elevator guy wasn't too happy because I got access to the shaft and was able to clean up a bit and add some cover to the box. I asked him to grant me some long term  privileges but he was visually uncomfortable with that conversation.
As to cost of the thing, I don't think it  makes any difference to him if it is replaced or fixed, they don't make money on selling stuff. I think it would be much more difficult to convince him to install repaired item If they did.
Offline Assafl
I would consider using conformal coating to protect the board. In Europe something like Plastic 70. Mask all connectors and do a few layers (I bake them in a 70 degree oven for an hour between layers).
One of the possible reasons the elevator guy was not happy is that elevator parts typically have safety functionality. Door controllers are usually listed under safety components. While not as important sounding as speed governor (the weird small wheel in the elevator machine room) - or the safety breaks - door malfunctions were responsible for a few elevator accidents.
For example, a door controller may limit the current to the motor to avoid pinching (which may have been taken out of calibration). May signal to the controller that it is safe to travel if the door is closed. May have protection timers if the door doesn't close/open in time. Sense if something is stuck in the door (like the hand of a small child or the leash of a dog) Etc.
In elevators, usually there is more than 1 safety - but using a repaired board whose safety features were not tested may pose a risk and may be an insurance liability.
There are few elevator accidents. See: https://en.wikipedia.org/wiki/List_of_elevator_accidents
BTW Even white goods: whenever you repair a white good (e.g. a dishwasher) keep in mind the possible "safety" implications. For example, if you repair a dishwasher pressure sensor using non-identical parts (which may be much cheaper than BSH or SMEG sourced components), you may be inviting flooding (yes - there is a float that will prevent that - but you went from having two safeties to 1). An overheating oven may be a fire risk. Etc.
« Last Edit: February 03, 2025, 07:34:07 am by Assafl »
CRC/KONTAKT CHEMIE Plastic 70 is for sure a suitable product for protecting the board.
The elevator accident list is unfortunately incomplete.
Offline Assafl
Poor kid. The entire weight of the cabin (and the hydraulic ram) was on his chest.
The operative concept in this case was that hydraulic elevators (which are usually very safe) are rare in France. ("L'ascenseur, de type hydraulique, rare en France,...").
So the technicians are not as experienced in their maintenance. Furthermore, they are not as "up-to-date" as to updates to ASML standards. So they end up using parts (old spare parts stock) that may have been identified as "unsafe".
The problem with "Safety" is that for the most part it isn't obvious. Why double check valves when one will do? An additional safety timer that never engages in a controller box? An "out of place" switch that seems to do nothing? An unidentifiable component?
From the outside a "safety relay" looks and works identical to a regular contactor. So why spend 10x on a force-guided safety relay? Also - what are the downstream effects if you use the wrong component? (if you are lucky you burn the motor; if unluck the elevator falls or the door severs someone's head).
  • Country: cy
I think it is a matter of trust. I'm not a teenager thinking about lift-surfing. I am a technician with years of experience who wants to look after our equipment in our building. If a certified guy from outside company doesn't believe I can handle basic procedures, I respect that.
Trust goes both ways thou. Now I only have more questions about why a 1000 euro part has to fail when it wouldn't if properly taken care of.
I'm too busy to thing about it too long. Passed my thoughts to the building owners and they will keep that in mind for the future.
Now in a second building I have an elevator that has been offline for 2 years now, and there will be lots more wrong with that. Several companies made it work and it kept on failing after a week or so. That is going to be fun!
I have no knowledge about elevators (*) but since they are often controlled by a PLC, checking power supplies, connectors, cables, sensor status and their mechanical positioning is probably part of the basic verification tasks. I hope you will succeed too. Gathering some documentation about that second elevator would certainly be useful to understand the wiring and have some explanation when error codes shiop up. It would be a great achievement that a third-party technician could turn the tide, while elevator repair companies keep stuck on the issue.
(*) first encounter was in this thread  :)
« Last Edit: February 05, 2025, 10:04:02 am by timeandfrequency »
  • Country: cy
I did 10000ft assessment of the elevator problem solving a while ago. If you understand electronics well enough you could probably fix it...(huge)BUT!!! The biggest bearer is software. I managed to obtain a manual to the mentioned elevator and many of it's components.
 If you turn on the thing on and self test shows any errors it will lock itself and without access to a proper scanner able to reprogram the controller you can't even troubleshoot the thing, it will stay dead. In some cases you may need multiple devices for doors controllers, motor controllers and other stuff. This topic is huge, dangerous and expensive. Never the less, one day I'm gonna start poking it with a stick.
