So I see the unit is rated 1150 W per channel, max. 3680 W total. What LED unit or whatever it is called, do you have connected up ? Is there some minimum load the Eurolite is expecting, and putting out too much power for your lights to be "off" ?
Is it a new Eurolite? Did it work right before or with other LED units ?
