This is the VFD display circuit from a Kenwood R5000 receiver.
The relevant part of the schematic (attached) to the problem is top right: Q4/5 oscillate at about 17kHz, the voltage on the secondary 4/5 of transformer T1 is rectified by D1/2/3/4 to produce about -20 Volts at the base of D6, a 3.9 Volt Zener. This part of the circuit works fine.
The secondary 9/10 of T1 is supposed to produce around 3 Volts AC to power the VFD filament across pins 1/2 and 39/40 of the VFD.
With D6 and C7 disconnected, this works ... about 3 Volts appears across the 9/10 secondary winding of T1.
However, with D6 and C7 connected as they should be, the voltage across the 9/10 secondary drops to zero, and then of course the VFD doesn't work. Since the filament has to be biassed a few Volts above the grids, this should be achieved by D6 ... that's my understanding at any rate. The "DC BIAS" measured value, instead of being -16.2 Volts, starts off at about -20 Volts, and then gradually keeps rising towards 0 Volts.
I've checked that D6 and C7 are good. Could anyone offer advice on what might be going wrong here, or other things I can check to help resolve the problem?
Thanks!
Julian
