I suspect something in the vertical module card with dozen of components no chips like the new ones , I get 220 volts DC in one place where I put my finger by mistake
. the inhibit signal looks good , I tried also with the 220 ohms resistor in pin 3- 11 in the control inhibit card, nothing is coming out , somebody here try it on putting the 5 volts in parallel with another power supply , in my OSD I need + -12 volts + - 5 volts and another secret + - there are in total 5 pairs or +_- lines to the OSD PCB card. looks very easy with another PC cheap P .Supply , but also there are synchronization cables maybe for the 50 hz self test in the only module schematics I found in the internet
the OSD was abandoned for 10 years , I suspect the condensers are gone
checking with a FLUKE Component testing ,I see the curves in this magic voltmeter with a small oscilloscope correct.
there is a laching relay in the front panel and PCBs cards that prevent the PS to power on , but again with the 200 ohms the manual said it can power on the PS If not change the PS ( 500 dolars and maybe I get one worse).
anyway thanks I live in Alkmaar now
near the cheese market
I am looking for an electronic atelier , before in ALMSTELVEEN the HP repaired and calibrated it , now is gone , any help will be appreciated .
