Hi guys,
I bought a Fluke 233 cheaply. The batteries in the display have run out. Thus the connections and the circuit board were damaged. Was able to clean everything so far and bring it back in order.
Only I have two problems:
1. The previous owner destroyed the L201 coil. For whatever reason.
could someone tell me which SMD coil is suitable?
Possibly also U202 and Q206?
I think, I have some problems with the Voltage.
When the battery voltage is high, it always restarts and the wireless function does not work either. It works fine with weaker batteries.
The coil is currently bridged.
2. the buzzer does not work. It is shown in the display. When I switch over in the resistance measurement. Unfortunately there is no sound. Does anyone have an idea of how to troubleshoot?
Thanks in advance
