Unfortunately, I can't draw enough amperage because I can only set the voltage up to a maximum of 1.9V and I don't have an appropriate load. While experimenting, I noticed the following:
When I connect a 21700 battery and set the device to 3.6V and 1A, the power supply's display shows 3.6V as expected.
However, when I connect my lowest resistance load and set the device to 1.9V (since I can't set it any higher) and 0.1A with OCP enabled, the power supply shuts off, which is expected behavior.
When I set the device to 10V without any load, turn on the output, and adjust the current from 0 to 5A in 0.1A increments, the voltage drops to 0V every 400-500mA. It's also worth noting that I never actually reach the 10V output voltage.
I hope this information is somehow helpful.
So I cant really say if current sensing/limiting works as expected, because of my limited knowledge to troubleshoot this
