Hi all
Having been a lurker on EEVblog for many years, I've just registered a user account in order to ask for help with my Korad KA6005P bench supply.
I have owned the above power supply for 13 months and up until now, it has performed flawlessly. Having just gone to use it again for the first time in a week or so, it appears to be having an issue outputting a stable voltage greater than 21V. Below 21V, everything appears to be okay, but with the output set to a higher value, the voltage quickly collapses to 21V where you can hear a relay switch. The voltage returns to the setpoint for the briefest of moments, then the voltage quickly collapses to 21V again and the cycle continues until the output is turned off manually.
I do not come from an EE background, but I am confident that I could repair the power supply if I knew what was at fault.
So, does anyone know what might be wrong?
Thanks in advance for any assistance you are able to provide.
Dan
