Author Topic: Problema em Osciloscópio FNIRSI 1013D  (Read 1417 times)
Offline jorge oliveiraTopic starter
  • Country: pt
« on: August 08, 2021, 03:06:57 pm »
Olá a todos!
Recebi esta semana um osciloscópio FNIRSI 1013D que comprei no AliExpress.  Comecei hoje a testa-lo e estou a detetar um problema ao selecionar a função "Probe mode 1X no canal 1", conforme vídeo que disponibilizo em:
Será que alguém pode ajudar na identificação do motivo pelo qual não consigo selecionar a função referida e se sabem alguma forma de resolver o problema?
Agradeço a ajuda!
Online tunk
  • Country: no
Re: Problema em Osciloscópio FNIRSI 1013D
« Reply #1 on: August 08, 2021, 03:17:28 pm »
English please - maybe you could use google translate?
The following users thanked this post: jorge oliveira
  • Country: pt
« Reply #2 on: August 08, 2021, 03:23:16 pm »
Hello everyone!
This week I received a FNIRSI 1013D oscilloscope that I bought on AliExpress. I started testing it today and I'm detecting a problem when selecting the "Probe mode 1X on channel 1" function, according to the video I have available at:
Can anyone help identify why I can't select the function referred to and if they know any way to solve the problem?
I appreciate the help!
Offline HB9EVI
« Reply #3 on: August 08, 2021, 03:51:36 pm »
hmmm, a bug??? wouldn't surprise me in those noname scopes without QC
Offline Rollin Hand
« Reply #4 on: August 09, 2021, 06:54:19 pm »
Can't returned to china,too much money to ship
Used like it is now until solution can come.
I have one with a noise channel no solution yet.
Online ledtester
« Reply #5 on: August 09, 2021, 07:08:28 pm »
Keep an eye on this thread:
https://www.eevblog.com/forum/testgear/fnirsi-1013d-100mhz-tablet-oscilloscope/msg3623711/#msg3623711
User pcprogrammer is reverse engineering the code and has made decent progress.
Online tunk
  • Country: no
« Reply #6 on: August 09, 2021, 07:12:27 pm »
If it's a firmware problem, then you could try to (re)flash it:
http://www.fnirsi.cn/support
Edit: Sorry, mixed the 1013D and 1014D.
Maybe you could try to contact Fnirsi and ask for advice?
« Last Edit: August 09, 2021, 07:15:19 pm by tunk »
Offline Felipe Lacerda
  • Country: br
« Reply #7 on: February 01, 2022, 08:20:14 pm »
FNIRSI support is extremely rude, toxic.
They consider everyone a threat to clone their products.
Firmware for the 1013D is not available.
The following users thanked this post: ESTechnical
Offline ESTechnical
    • ESTechnical - Reflow ovens and controllers
« Reply #8 on: February 02, 2022, 01:54:21 pm »
I will make sure I avoid recommending their products, if that is their attitude towards support! Thanks for the heads-up!
Offline Slartibartfast
« Reply #9 on: February 02, 2022, 03:17:19 pm »
Sometimes support is rude because customer comes with entirely unreasonable expectations, and then upon finding expectations won't be satisfied starts to be rude first.
I would never draw such a conclusion based on the report of a single person, even less if I do not know that person.
Cheers  Peter
Online tunk
  • Country: no
« Reply #10 on: February 02, 2022, 03:40:15 pm »
A couple of years ago I got a Fnirsi DSO PRO that didn't
come with a manual. I contacted them asking for a PDF or if
they could put it on their web-site. The reply was to contact
the seller. I seem to remember that wording of the reply was ok,
but this shows that they doesn't care much about the users of
their products.
Offline pcprogrammer
« Reply #11 on: May 24, 2022, 05:24:17 am »
A bit late but the problem I see in the video could be the touch panel. It looks very similar to what others and I experienced, where parts of the touch panel fail to respond to touch.
As user ledtester suggested take a look in the thread I wrote about the reverse engineering. It starts to get into the touch panel problem just before this post: https://www.eevblog.com/forum/testgear/fnirsi-1013d-100mhz-tablet-oscilloscope/msg3425900/#msg3425900 This is where it becomes more and more about the actual problem and leads to the reverse engineering.
Repairing it is possible with a new touch panel from Aliexpress and some skill. Be aware that the front glass panel can break, which you can read about in the other thread |O
