Author Topic: Samsung PS-42V4S 42" Plasma TV  (Read 6405 times)
Offline Mad ProfessorTopic starter
Re: Samsung PS-42V4S 42" Plasma TV
« Reply #25 on: September 14, 2017, 07:36:53 pm »
C13 has been replaced with a new electrolytic capacitor. and still acting the same.
Here are the results from more testing as requested.
I have also attached the SMPS schematic in pdf format, please see below.
Thanks again.
« Last Edit: September 14, 2017, 07:42:08 pm by Mad Professor »
Offline Armadillo
« Reply #26 on: September 14, 2017, 09:30:21 pm »
Hi;
Firstly Diode Check D801 and D19. Are they OK?
If Yes;
Turn On the TV and measure the voltage at cathode of D801 with respect to Pin 10 of IC1 [gnd].
Is the voltage > 3.5v?
If yes;
Then measure the voltage at the cathode of D19 with respect to Pin 10 of IC1 [gnd].
If yes;
Then measure VC_S_F with respect to Pin 10 [gnd] of IC1  [see attached]
Is voltage > 15 V?
If Yes;
Turn Off TV
Set meter to Diode mode, Check PC1S, measure across Pin 4 and Pin 3 for shorts.
Is the measurement OK?
Double confirm C13 that the newly installed Cap is OK, measure ESR, confirm +ve lead is to Pin 5 of IC1.
If YES, then you will have to replace IC1. $1.30 from China. We went through a lot of troublesome steps to confirm this.
Please post results.
Edit:
If No VC_S_F;
Measure the voltages shown in attached and post results.
« Last Edit: September 14, 2017, 11:05:40 pm by Armadillo »
« Reply #27 on: September 15, 2017, 02:02:10 pm »
Hi;
If Yes; Tested ok
If yes; 16.83v
If yes; 19.56v
Is voltage > 15 V?
If Yes; 18.01v
Turn Off TV
Is the measurement OK? Seems ok
The replacement cap was a brand new electrolytic capacitor 50v10uf Rubycon YXF
So you are saying by the above, and my readings that it does indeed look to be that IC1 is at fault.
Where would be the best place to buy a new IC1 (ML4824)?
Thanks again for your time.
Offline Armadillo
« Reply #28 on: September 15, 2017, 02:07:27 pm »
Yes, you should replace the defective ML4824. you can get it from ebay in china. Suggested below, but please check your package type etc... I have not buy from them before.
http://www.ebay.com/itm/ML4824IP1-DIP-16-IC-Power-Factor-Controller-BIPOLAR-/322563116018?hash=item4b1a428bf2:g:-nIAAOSw~y9ZEspg
You can search around.
Edit; What do you mean by "Seems OK"?.
« Last Edit: September 15, 2017, 02:10:28 pm by Armadillo »
Offline Armadillo
« Reply #29 on: September 15, 2017, 02:23:41 pm »
The capacitor C13 is for timing the Soft Starting of the TV.
Normally it is 2.2 uf because the charge current is really small from the IC.
I wonder why your schematic shows 10uf, no wonder the IC is short lived.
Now while your IC is on the shipment;
Can you try to install a 2.2uf 50V electrolytic capacitor [low leakage type] onto C13 and try again. If you are not sure about PC1S, temporary remove it from the circuit.
You can install back when the IC arrived.
See the schematic attached.
Offline wraper
  • Country: lv
« Reply #30 on: September 15, 2017, 02:38:53 pm »
Before ordering ML4824, measure reistance between IC1 pin 5 and 10 to see if there is no low resistance. Also I suggest removing PC10S, if it does not help, also remove Q78 to ensure that nothing is preventing IC1 pin 5 from going hi.
« Reply #31 on: September 15, 2017, 07:11:34 pm »
The resistance between IC1 pin 5 and 10, is not a stable reading but in the megaohm range.
I also removed PC10S & Q78, I still get the same 0.4v at pin 5 of IC1.
Offline Armadillo
« Reply #32 on: September 15, 2017, 07:46:57 pm »
That should confirm defective IC1. Order and replace it. Any way to get it locally and quickly.?
We wait to hear the good news from you.    ;)
« Reply #33 on: September 20, 2017, 07:36:04 pm »
I would like to thank you all again for your replies, and helping confirm that IC1 (ML4824) was faulty.
I ordered a new replacement ML4824 from a UK eBay seller, and received it today.
After refitting the removed components for testing, and fitting the new IC, the TV fired into life, fully back up and working.
Thanks again  :-+
The following users thanked this post: wraper
