Author Topic: Problems with Multimeter Vichy VC97  (Read 1024 times)
Offline nForceTopic starter
  • Country: ee
« on: October 19, 2019, 03:21:15 pm »
When I was testing the multimeter for resistance and continuity, I notice that most of the time the multimeter does not read the value of the resistance. Also for continuity, it does not beep. Occasionally it does work, but not most of the time. When not working I get ".0L" reading. I don't understand why? I reset the meter a few times, but also the same problem.
Did anyone had any similar problems?
Offline PKTKS
  • Country: br
Re: Problems with Multimeter Vichy VC97
« Reply #1 on: October 19, 2019, 04:01:30 pm »
No
They have fairly good quality
But considering overall cost of similar product class ...
- Check the probes - several times they are bad.
  they are mostly got from other supplier in chain
- Open the DMM and check the solders of the probes on pcb
  several times they are bad either. Usually they are hand made
  on a not very good production line
-  Perform overall visual inspection - cold or bad joints do happen a lot
All very easy to fix.. and very common.
Mostly you will need another DMM as well
Last  but not least the ROTARY POSITIONAL KEY..
very frequently they have some issues.. more or less fixable.
Paul
The following users thanked this post: nForce
Offline mzacharias
« Reply #2 on: October 20, 2019, 12:39:55 am »
Bad test leads?
