Author Topic: Prodigit 2000MU energy meter repair - resistor value  (Read 294 times)
Offline kamalTopic starter
  • Country: lk
« on: January 01, 2025, 12:11:54 pm »
One of the resistors of this Prodigit 2000MU energy meter has burned. Please see the attachment. I replaced it with a 10k but it still gets hot.
It appears to be a 2 or 3W resistor. Can someone let me know the correct value of it?
Offline HighVoltage
Re: Prodigit 2000MU energy meter repair - resistor value
« Reply #1 on: January 01, 2025, 12:18:53 pm »
Well, there is a good possibility that something else is wrong.
You need to check the circuity after this resistor to find out what is pulling this current wrongly.
  • Country: lk
« Reply #2 on: January 01, 2025, 12:31:18 pm »
Thanks for the suggestion. I'll keep a tab on that.
At the moment my guess is that for some reason the resistance got increased and hence the larger voltage drop caused it to heat up and finally failed. I wonder if the value is like 100 ohms. 10k won't be a match then and explains why it continues to heat up. Before trying with other resistance values, I thought of seeking help.
  • Country: lk
« Reply #3 on: January 07, 2025, 06:23:11 am »
After looking at the capacitive power supply circuit, I determined that a 100 ohms wouldn't cause a problem so replaced the resistor with a 100 ohms 3W one. No more abnormal heating of the resistor, the device is working well now.
