Greetings from Serbia,
I came into possession of the Australian oscilloscope BWD from 1987, serial number: 41649. The oscilloscope was faulty but I partially enabled it. My first step was to replace all the electrolytic capacitors. Then I fixed the faulty intensity potentiometer after which I got the picture actually a trace. I adjusted all positions according to the instructions for the first start. I got a pale and flickering dot on the screen.
https://manual-hub.com/manuals/bwd-539d-01-pdf-manual/Then turned on the X-Y button and brought the X wire to the input with my finger😊 In the attached picture you can see that the oscilloscope reacted which means that the X amplifier is good.
Then I inspected the TB / X-Y switch and it seems ok to me. Focus changes sharpness also. Switch s201 works ok as far as I could measure.
I reviewed the Q253 Q255 bi- stabile trigger, Q257 miller saw generator and Q256. The component test says they are good after I took them off the PCB.
I would ask you if anyone has any advice? Thanks.
Djuma
