Author Topic: Programmable version of the TTi PL series Power Supply  (Read 1334 times)
Offline EHTTopic starter
« on: January 25, 2022, 09:29:34 pm »
Hi All,
I'm after the service manual / schematic for the *Programmable* version of the classic TTi PL series PSU. The normal versions are PL330QMD, PL330QMT etc., the GPIB ones are PL330DP, PL330TP. The manual for the non programmable version is easily found, e.g. here, but this manual says:
This Service Manual is for the revised PL models introduced from mid-1991, with the exception of the PL-P 3Amp programmable models which are covered by a separate manual
I can find the instructions but not svc / schematic. I guess they are quite rare items? Maybe got superseded by their other ranges quickly?
Offline Swake
Re: Programmable version of the TTi PL series Power Supply
« Reply #1 on: November 09, 2023, 11:11:14 pm »
Have you found any service or repair information about the GPIB/RS232 interface itself?
Got a triple output PL330TP. The third output works perfectly well as long as it is not connected to the communications board. As soon as it is connected the output stays at 0V. As if it is controlled remotely. The setting of the local/remote button does not change anything this.
When it fits stop using the hammer
Offline watchmaker
  • Self Study in EE
    • Precision Timepiece Restoration and Service
« Reply #2 on: November 10, 2023, 02:33:33 pm »
Attached.  TSX maybe it will help.
Regards,
Dewey
« Last Edit: November 10, 2023, 02:35:12 pm by watchmaker »
Regards,
Dewey
The following users thanked this post: Swake
Offline Swake
« Reply #3 on: November 10, 2023, 04:12:30 pm »
Thanks for this manual.
It does not match completely but there are quite some similarities. The controller and V/A displays for the power supply modules have very similar schematics. There is a PIC16C55XT and in the schematics that you provided the pins 6 to 8 are referenced to talk to the communications board. They call it an 'Inter-Processor-Interface'.
My communications board has a Z80 CPU too but that is about where the similarity ends. However, I think that the 'Inter-Processor-Interface' will be setup in a similar way and that will help understanding how things work and hopefully debug it.
Btw, just found a half-dead capacitor on the CPU power supply for the second channel. The channel was always acting up on startup for a couple of minutes, then it was working fine as if nothing happened. I finally decided to dig into it with a scope today and found the +5V to have more ripple than seemed healthy, after a few minutes the ripple mostly disappeared.
Online Andy Watson
« Reply #4 on: November 10, 2023, 10:53:56 pm »
Don't know if this will be of any help, but:
A while ago i reverse-engineered the GPIB interface for a PL320.  This was single-output power supply, however, the GPIB appears to have been designed for two channels.
The GPIB module appears to be very much an after-thought - almost a prototype in construction. There were two PCBs to the GPIB module; a processor board with the actual GPIB, and an interface board which opto-isolated serial signals from the processor and provided DACs for the voltage setting.
The interface board uses CMOS switches (4066) to switch between local and remote control. My guess would be that one of these switches is defunct.
My attempt at reversing the schematic is below:
I never got the GPIB working. The EPROM had suffered extreme bit-rot - it was mostly FFh and obviusly not a program of any sort :(
Edit: P.S. I was bemused by the extra, redundent connections on the processor PCB, and some odd cut-outs which were also unecessary in the PL320. Sometime later I discovered that TTi had borrowed the processor board from their 1905A multimeter GPIB - hence the redundent features!
« Last Edit: November 10, 2023, 11:07:05 pm by Andy Watson »
Offline Swake
« Reply #5 on: November 12, 2023, 09:50:59 am »
Thanks Andy, interesting information.
Having experience with only one of the power supplies it is very clear this thing evolved over time. First a power section only, likely with analog meters. Then the digital readout was added based on a PIC. Using a µC was smart actually as using a separate AD was the only way to go to have 4 full digits in the readout and allowed for evolution afterwards such as with the numerical keyboard. I believe cheap of the shelf chips only offered 3.5 digits at the time. After that a communications board was added, I understand in 2 distinct phases and likely by 2 other engineers judging first a 6502 CPU and then a Z80 was used.
They where also very cost conscious and used relatively good quality components with all widely available stuff and a somewhat modular setup. Need 1 more amp? Just sandwich another heatsink with power transistor on top of the previous one. Need 2 PS? Well... put 2 in a wider box. Mine is a 3 channel version and it has 3 of everything including 3 transformers and 3 sets of heatsink.
You know what these don't have?? A fan! And that my dear friend is a blessing to the ears and the reason I keep it on the workbench.
Offline voltsandjolts
« Reply #6 on: November 12, 2023, 04:07:46 pm »
TTi PL series are great units.
PL-P service manual has GPIB schematic on second last page, but I'm sure there are a few revisions in this series so may not be exactly what you have.
The following users thanked this post: Andy Watson, Swake
Offline Swake
« Reply #7 on: November 12, 2023, 04:53:42 pm »
Yes  :-+ That is the service manual I needed, thank you very much  :D
