Author Topic: Power Designs Model 4050 Repair  (Read 3693 times)
Offline cspearowTopic starter
« on: April 23, 2015, 06:48:59 pm »
I just bought a Power Designs Model 4050 power supply. 0-40 V @ 5 A. It weighs a ton.
The output voltage is fine, but the current limit has a problem. It shows 5 A when it's actually sourcing 150 mA, and it current limits accordingly.
This shouldn't be too hard to figure out, but I can't find a schematic anywhere, for the 4050 or similar units from Power Designs. This seems odd, because it's a pretty popular line of power supplies.
Does anybody have a secret source for Power Designs schematics or service manuals?
-Carl
Offline mzacharias
Re: Power Designs Model 4050 Repair
« Reply #1 on: April 24, 2015, 05:20:05 pm »
Just a guess - maybe a burned resistor?
« Reply #2 on: April 24, 2015, 08:46:23 pm »
I think I found the problem.
 There is a wirewound power resistor, marked 0.25 ohm. It looks like a 25W tubular ceramic. I'm pretty sure it's the output current sense resistor.
I measured it with a 4-wire meter, and it measured 24 ohms. I removed it from the unit, and then it measured 26 ohms. Then I applied some power to it, and it seems to have changed to 0.5 ohms. Freaky.
There is no physical damage that I can see. I wouldn't think such a failure would be common. It doesn't run hot.
I couldn't find one exactly like that, but I found a different style on Digi-Key, and it's on order. We'll see how it goes.
« Reply #3 on: April 25, 2015, 06:53:22 am »
Probably has a cracked connection to the internal resistance wire coil. Very common on power resistors after they have had a lot of thermal cycles, though this one with 6W or so of dissipation at most should not have failed, it probably had a manufacturing fault where the crimping operation nearly cut through the wire and this eventually fatigued open, the high resistance being from the last piece still joining the 2 sections of wire.
« Reply #4 on: May 05, 2015, 04:35:54 pm »
The power supply is running now.
The only problem is that the current meter is off. It reads about 3 A when the output current is 5 A.
There are several unmarked trimpots on the board, but frankly, I can't be bothered trying to figure it out with trial-and-error methods, so I closed it up and that's that.
$41 out the door (plus some time)  for a 200W bench power supply. I can live with that.
Online SingleBitError
« Reply #5 on: January 17, 2017, 05:56:06 pm »
I recently restored a 4050 that I bought at auction a couple years ago. After having no luck finding a manual online I found one on ebay. Spent more for the manual than the 4050.
I finally got around to scanning the manual to PDF. I uploaded the manual to the KO4BB site. Should be out of quarantine soon.
The following users thanked this post: saturation, bitseeker
Offline bitseeker
« Reply #6 on: January 18, 2017, 04:33:36 pm »
Thanks for uploading that, SingleBitError.  :-+ Some models are rather obscure, especially when it comes to documentation.
