I have wired up the serial debug port on my DIA-002 board based PS3. When I run the Sysconreader program (Link:
https://github.com/db260179/ps3syscon/tree/master/SysconReader) on windows I can successfully auth the system but when I try and read the codes the output log does not make any sense. I have copied the log below. I am using a Pl-2303 based serial adapter and using a special driver to get it to work under windows (search for PL2303_64bit_Installer.exe if you want to try the driver that I am using). Not sure if this is part of my problems. Also just have the main PS3 PCB and power supply connected to each other and no other things attached (fan, hard drive, disk drive, wi-fi board). The issue with the unit is that it tries to turn on but then goes to a flashing red light with 3 beeps (I can make a video of it if you want). I know it is not overheating as the thermal past has been already replaced and the issue happens within a few seconds of it trying to turn on. Got any ideas what may be wrong?
ERR 00: 00000000 FFFFFFFF FFFFFFFF
ERR 01: 00000000 FFFFFFFF FFFFFFFF
ERR 02: 00000000 FFFFFFFF FFFFFFFF
ERR 03: 00000000 FFFFFFFF FFFFFFFF
ERR 04: 00000000 FFFFFFFF FFFFFFFF
ERR 05: 00000000 FFFFFFFF FFFFFFFF
ERR 06: 00000000 FFFFFFFF FFFFFFFF
ERR 07: 00000000 FFFFFFFF FFFFFFFF
ERR 08: 00000000 FFFFFFFF FFFFFFFF
ERR 09: 00000000 FFFFFFFF FFFFFFFF
ERR 10: 00000000 FFFFFFFF FFFFFFFF
ERR 11: 00000000 FFFFFFFF FFFFFFFF
ERR 12: 00000000 FFFFFFFF FFFFFFFF
ERR 13: 00000000 FFFFFFFF FFFFFFFF
ERR 14: 00000000 FFFFFFFF FFFFFFFF
ERR 15: 00000000 FFFFFFFF FFFFFFFF
ERR 16: 00000000 FFFFFFFF FFFFFFFF
ERR 17: 00000000 FFFFFFFF FFFFFFFF
ERR 18: 00000000 FFFFFFFF FFFFFFFF
ERR 19: 00000000 FFFFFFFF FFFFFFFF
