Further my earlier message, I am able to see some voltages on the ic's though I haven't checked in detail, but there is a diode array DT1042-04TS-7 which is perhaps connected to a coil or transformer, which shows zero voltage on all its 6 terminals.
The continuity also shows zero ohms in both directions, I have not taken it out of the circuit to check.
Perhaps somebody here can guide me if this is how it should be.
Thanks.
spd
