Author Topic: Putting a 7 segment LCD back in place  (Read 2076 times)
Offline MartiniTopic starter
« on: April 10, 2016, 03:43:15 pm »
Hey !
My $10 "precision" scale gave up the other day. Its only problem is with the LCD screen. Some traces looked broken at their (metaphorical) hinge, so I thought I could unglue the ribbon and move it one millimeter. But the black traces were full of glue and didn't make contact. So I cleaned them, now the ribbon doesn't stick ;D
Any idea about connecting the screen back to the PCB?
(Knowing I don't have conducting glue)
Re: Putting a 7 segment LCD back in place
« Reply #1 on: April 10, 2016, 03:58:31 pm »
Normally done with a hot bar sealer, but doable if you have a temperature controlled iron and set it around 150C to melt the plastic back to the clean board.
Offline amyk
« Reply #2 on: April 10, 2016, 04:12:16 pm »
Anisotropic conductive tape could be an easier solution if you can find some.
Online wraper
  • Country: lv
« Reply #3 on: April 10, 2016, 04:23:39 pm »
Z-axis conductive tape would do the job http://www.ebay.com/itm/262379455349. However it is expensive (that price is for a tiny piece) and won't help anyway. By tearing off that ribbon cable, you destroyed it beyond repair. Conductive traces from the cable remained on the PCB, what left on the cable is insulated from the both side and therefore is not accessible. And you won't be able to remove the insulating layer without damaging the traces anyway. So just buy another scales.
« Reply #4 on: April 10, 2016, 05:07:29 pm »
Wow, those tapes look cool, I didn't know such solution existed.
That didn't work at 150°C, I'll try to up the temp a bit tomorrow when I have more light to work.
Resistance of the black traces is a few hundred ohms when the probes are 5 mm apart. Is that congruent with the insulation you're talking about?
Online wraper
  • Country: lv
« Reply #5 on: April 10, 2016, 05:19:57 pm »
Dunno, maybe some super cheap uninsulated type. Few hundred ohms is about right resistance for carbon traces.
Offline amyk
« Reply #6 on: April 11, 2016, 09:33:30 am »
Physically hold it in place (firmly) if you want to test whether it will work. If there's any conductivity it should, LCDs don't require much current at all to operate.
« Reply #7 on: April 11, 2016, 09:45:47 am »
Oh, it does. But it's really tricky to align and put pressure on all the contacts at the same time.
