The attached schematic image shows part of a PLL in a Kenwood R5000 receiver.
I'm puzzled by the voltages shown around Q7, a 2SC2668 transistor, and hoping someone can explain them.
The Collector has a voltage of 2.8V, which is derived via R53 (1.2kOhm) from the supply of 8.6V. The Base has a marked voltage of 7.2V.
This does not make sense to me, so clearly I don't understand how the circuit functions! Shouldn't the Base voltage be set by the voltage divider R51/R52 (22k,33k), so about 22/55*2.7 i.e. ~1V?
How can the Base voltage be higher than the Collector voltage in this circuit?
Thanks!
